Alex
April 17, 2007, 8:28am
1
Hi.
RUN AT COMMAND============================================
StrReturn = adl_atCmdCreate( “AT+CGATT?”, FALSE, (adl_atRspHandler_t) CGATT_Handler ,"*",NULL );
Handler===============================================
bool CGATT_Handler( adl_atUnsolicited_t * CGATT_paras )
adl_atSendResponse ( ADL_AT_UNS, CGATT_paras->StrData);
return True
I see in terminal : +CREG: 2,1,“43ED”,“254F”
Why comes not correct answer???
Beforehand grateful.
Hi alex !
Do you send AT+CREG command in your application ? Using the same handler ?
You maybe should post your code here to see if we can find something…
Alex
April 17, 2007, 9:25am
3
hi colin-tfe
adl_atCmdCreate( “AT+CREG?”, FALSE, (adl_atRspHandler_t) CregHandler ,"*",NULL );
HANDLER(AT+CREG?) - CregHandler…
and
HANDLER(AT+CGATT?) - CGATTHandler…
tobias
April 17, 2007, 9:35am
4
For testing purposes you could use ADL_AT_RSP instead of ADL_AT_UNS.
So maybe "+CREG: 2,1,“43ED”,“254F” " comes from CREG response Handler !
To be sure, do someting like this :
adl_atSendResponse ( ADL_AT_UNS, "CGATT Response : ");
return True
bool CREG_Handler( adl_atUnsolicited_t * CREG_paras )
adl_atSendResponse ( ADL_AT_UNS, "CREG Response : ");
adl_atSendResponse ( ADL_AT_UNS, CREG _paras->StrData);
return True
Alex
April 17, 2007, 10:01am
6
colin-tfe
I try , but result not changed
But does really “+CREG: 2,1,“43ED”,“254F”” come from CGATT response handler ???
Or does “+CREG: 2,1,“43ED”,“254F”” come from CREG response handler and maybe nothing comes from CGATT response handler…?
There is no reason for receiving “+CREG” response afer sending command “AT+CGATT?”…!
Alex
April 17, 2007, 10:19am
8
I understand, but this exactly so !!!
Alex
April 17, 2007, 10:22am
9
CGATT Response :
+CREG: 2,1,“1E37”,“4EE2”
Cgatt answer … +
Cgatt answer … C
Cgatt answer … R
Cgatt answer … E
Cgatt answer … G
Cgatt answer … :
Cgatt answer …
Cgatt answer … 2
Cgatt answer … ,
Cgatt answer … 1
Cgatt answer … ,
CGATT Response :
Cgatt answer … O
Cgatt answer … K
Cgatt answer …
awneil
April 17, 2007, 10:34am
10
Unless it’s an Unsolicited response…
The general form of a +CREG: response is:
+CREG: , [,,]
So +CREG: 2,1,“1E37”,“4EE2” has =2 - which means that unsolicited +CREG: responses are enabled! 8)
See the AT+CREG command for details of how to control unsolicited +CREG: responses…
And CREG_Handler is never called ??? Are you sure you’re not sending the CREG command with the CGATT_Handler ??
Well, there is a possibility to do what you want, but this wont explain why you receive “+CREG” response after “CGATT?” command.
So, when you send a command using adl_atCmdCreate() function, you define a response handler. But you specify which response(s) you want to handle too… then :
For CGATT :
StrReturn = adl_atCmdCreate( "AT+CGATT?", FALSE, (adl_atRspHandler_t) CGATT_Handler ,"+CGATT",NULL );
CGATT_Handler will only be called if +CGATT response is received after sending the command.
For CREG :
StrReturn = adl_atCmdCreate( "AT+CREG?", FALSE, (adl_atRspHandler_t) CREG_Handler ,"+CREG",NULL );
CREG_Handler will only be called if +CREG response is received after sending the command.
tobias
April 17, 2007, 10:53am
12
I think you’ll need to post what module and what version of the firmware and OpenAT that is being used.
Alex
April 17, 2007, 10:59am
13
if I run AT+CREG? in tenminal , I response answer +CREG:0,1
Alex
April 17, 2007, 11:06am
14
I used:
1- CREG
2- CGATT (after CREG and reseive answer from CREGHandler)
3- And in this time I take call.
4- OS- 655
But can be this because of that that I take call in this time?
