HTTPSGET big latency on HL6528RD
Hi all,
We are trying to open an HTTPS session with mutual authentication to perform a GET operation from HL6528RD (FW version: 2.5.1.11).
When we send AT+KHTTPSGET command, we have big latencies, i.e.:
  • average 20s to have CONNECT response
  • average other 20/30s to have the response itself (GET content)
An example of the AT commands we are using:
AT+KHTTPSCFG=1,“server_url”,server_port,0,7,3, , ,1
AT+KHTTPSGET=1,“path”
This happens with or without server/mutual authentication, and with different servers.
If we do the same with e.g. postman, it takes about 1-2s to have the overall response.
What may it depend on?
Thanks in advance,
Sabino
Hi @sabinocolonna,
I followed your command on our module. It takes about 5-6s to complete. I thinks this the duration looks OK.
at+khttpscfg=1,“google.com
+KHTTPSCFG: 1
at+khttpsget=1,“path”
If your module gets quick response from postman, the reason might be from server that you are connecting to. Please contact administrator for more technical support
Hi @Vianney,
We tried the same HTTPSGET to “google.com” and got different timings for CONNECT response:
  • trial #1: 13s
  • trial #2: 6s
  • trial #3: 12s
  • trial #4: 31s
  • trial #5: 13s
Please, notice that the signal quality is really good:
AT+CSQ → 31,99
and that we are using a SIMonChip with roaming operator.
May it be a reason of such a latency and variability in our results?
Is your module HL6528RD?
Sabino
Hi @sabinocolonna,
I shared the result from HL6528RD. It got a response from google page within 5- 6 s same your trial #2. I believe it’s OK from the module. There’re many factors causing latency and roaming network might be one of them
