“gpio wakeup is not defined” ==>> how to wakeup gpio
[ 270.222340] mmc0: new high speed SDIO card at address 0001
[ 270.283950] wfx-sdio mmc0:0001:1: Device is not declared in DT. Features will be limited.
[ 270.285334] wfx-sdio mmc0:0001:1: GPIO lookup for consumer wakeup
[ 270.285351] wfx-sdio mmc0:0001:1: using lookup tables for GPIO lookup
[ 270.285364] wfx-sdio mmc0:0001:1: lookup for GPIO wakeup failed
[ 270.285377] wfx-sdio mmc0:0001:1: gpio wakeup is not defined
[ 270.285386] get gpio
[ 270.285468] mmc0: data txfr (0x00200000) error: -84 after 0 ms
[ 270.290265] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 270.290275] sdhci: Sys addr: 0x00000000 | Version: 0x00002e02
[ 270.290285] sdhci: Blk size: 0x00000004 | Blk cnt: 0x00000001
[ 270.290295] sdhci: Argument: 0x94000004 | Trn mode: 0x00000003
[ 270.290305] sdhci: Present: 0x01f80100 | Host ctl: 0x00000017
[ 270.290315] sdhci: Power: 0x0000000d | Blk gap: 0x00000000
[ 270.290325] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 270.290335] sdhci: Timeout: 0x0000000b | Int stat: 0x00000000
[ 270.290345] sdhci: Int enab: 0x03ff810b | Sig enab: 0x03ff010b
[ 270.290355] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 270.290365] sdhci: Caps: 0x262dc8b2 | Caps_1: 0x00008007
[ 270.290375] sdhci: Cmd: 0x0000353a | Max curr: 0x00000000
[ 270.290385] sdhci: Resp 1: 0x00000000 | Resp 0: 0x00002000
[ 270.290395] sdhci: Resp 3: 0x00000000 | Resp 2: 0x00000000
[ 270.290404] sdhci: Host ctl2: 0x00000000
[ 270.290414] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x8f44c008
[ 270.290424] ----------- VENDOR REGISTER DUMP -----------
[ 270.290435] Data cnt: 0x00000000 | Fifo cnt: 0x00000000 | Int sts: 0x000c0000
[ 270.290446] DLL cfg: 0x60086400 | DLL sts: 0x00000000 | SDCC ver: 0x1000002e
[ 270.290457] Vndr func: 0x00008a1c | Vndr adma err : addr0: 0x00000000 addr1: 0x00000000
[ 270.290466] Vndr func2: 0xfa8018a8
[ 270.290510] Test bus[0 to 3]: 0x0000c846 0x000020ce 0x00007118 0x01c101ff
[ 270.290521] Test bus[4 to 7]: 0x0046bfd8 0x0024c038 0x40000000 0x0003ffff
[ 270.290532] Test bus[8 to 11]: 0x47fc0604 0x40800002 0x201be089 0x000004c0
[ 270.290544] Test bus[12 to 15]: 0x034f0408 0x843f1180 0x0d001c18 0x00800a80
[ 270.290554] Test bus[16 to 19]: 0x00012000 0x000f804c 0x00000000 0x00000c91
[ 270.290565] Test bus[20 to 23]: 0x0240ff01 0x00058021 0x00000000 0x00000000
[ 270.290575] Test bus[24 to 27]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 270.290585] Test bus[28 to 31]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 270.290595] Test bus[32 to 35]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 270.290605] Test bus[36 to 39]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 270.290616] Test bus[40 to 43]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 270.290626] Test bus[44 to 47]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 270.290636] Test bus[48 to 51]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 270.290646] Test bus[52 to 55]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 270.290656] Test bus[56 to 59]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 270.290668] mmc0: clk: 50000000 clk-gated: 0 claimer: kworker/u2:0 pwr: 12 host->irq = 8192
[ 270.290678] mmc0: rpmstatuspltfm(0:1:0)
[ 270.290687] sdhci: ===========================================
[ 270.293196] wfx-sdio mmc0:0001:1: write32: bus communication error: -84
[ 270.298776] wfx-sdio mmc0:0001:1: bus returned an error during first write access. Host configuration error?
[ 270.344702] >>>>>>>> err2
[ 270.345590] wfx-sdio: probe of mmc0:0001:1 failed with error -5
