I got the error in dmesg ( wfx-sdio mmc0:0001:1: read32: bus communication error: -110 )
and cannot found “WLAN0” on wp7605
Should I have to setting something to get wlan0??
DMESG;
[ 123.530016] wfx-sdio mmc0:0001:1: device is not declared in DT, features will be limited
[ 123.530876] wfx-sdio mmc0:0001:1: GPIO lookup for consumer wakeup
[ 123.530895] wfx-sdio mmc0:0001:1: using lookup tables for GPIO lookup
[ 123.530912] wfx-sdio mmc0:0001:1: lookup for GPIO wakeup failed
[ 125.211029] mmc0: data txfr (0x00100000) error: -110 after 1679 ms
[ 125.216204] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 125.216220] sdhci: Sys addr: 0x00000000 | Version: 0x00002e02
[ 125.216236] sdhci: Blk size: 0x00000004 | Blk cnt: 0x00000001
[ 125.216252] sdhci: Argument: 0x14000004 | Trn mode: 0x00000013
[ 125.216267] sdhci: Present: 0x01f80206 | Host ctl: 0x00000017
[ 125.216282] sdhci: Power: 0x0000000d | Blk gap: 0x00000000
[ 125.216298] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 125.216314] sdhci: Timeout: 0x0000000a | Int stat: 0x00000000
[ 125.216330] sdhci: Int enab: 0x03ff800b | Sig enab: 0x03ff000b
[ 125.216344] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 125.216361] sdhci: Caps: 0x262dc8b2 | Caps_1: 0x00008007
[ 125.216376] sdhci: Cmd: 0x0000353a | Max curr: 0x00000000
[ 125.216391] sdhci: Resp 1: 0x00000000 | Resp 0: 0x00002000
[ 125.216406] sdhci: Resp 3: 0x00000000 | Resp 2: 0x00000000
[ 125.216420] sdhci: Host ctl2: 0x00000000
[ 125.216436] sdhci: ADMA Err: 0x00000003 | ADMA Ptr: 0x8f46c008
[ 125.216449] ----------- VENDOR REGISTER DUMP -----------
[ 125.216469] Data cnt: 0x00000004 | Fifo cnt: 0x00000004 | Int sts: 0x000c0000
[ 125.216486] DLL cfg: 0x60026400 | DLL sts: 0x00000000 | SDCC ver: 0x1000002e
[ 125.216503] Vndr func: 0x00008a1c | Vndr adma err : addr0: 0x008d3440 addr1: 0x00000000
[ 125.216516] Vndr func2: 0xfa8018a8
[ 125.216600] Test bus[0 to 3]: 0x0000c846 0x000020ce 0x00007118 0x01c102ff
[ 125.216617] Test bus[4 to 7]: 0x0046bfd8 0x0026c038 0x40000000 0x0003ffff
[ 125.216634] Test bus[8 to 11]: 0x47fc0604 0x40800002 0x202be089 0x000004c0
[ 125.216651] Test bus[12 to 15]: 0x054f0408 0x843f0180 0x0d000000 0x00800a80
[ 125.216667] Test bus[16 to 19]: 0x10012002 0x000f80cc 0x00000000 0x00001491
[ 125.216684] Test bus[20 to 23]: 0x0240ff01 0x00050021 0x00000000 0x00000000
[ 125.216699] Test bus[24 to 27]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 125.216714] Test bus[28 to 31]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 125.216730] Test bus[32 to 35]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 125.216745] Test bus[36 to 39]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 125.216761] Test bus[40 to 43]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 125.216776] Test bus[44 to 47]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 125.216792] Test bus[48 to 51]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 125.216807] Test bus[52 to 55]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 125.216823] Test bus[56 to 59]: 0x00000000 0x00000000 0x00000000 0x00000000
[ 125.216840] mmc0: clk: 20000000 clk-gated: 0 claimer: kworker/u2:7 pwr: 12 host->irq = 8192
[ 125.216856] mmc0: rpmstatus[pltfm](runtime-suspend:usage_count:disable_depth)(0:1:0)
[ 125.216868] sdhci: ===========================================
[ 125.217093] wfx-sdio mmc0:0001:1: read32: bus communication error: -110
[ 125.226236] wfx-sdio mmc0:0001:1: bus returned an error during first read access. Bus configuration error?
[ 125.241116] wfx-sdio: probe of mmc0:0001:1 failed with error -5
root@swi-mdm9x28-wp:~# ifconfig -a
bridge0 Link encap:Ethernet HWaddr 62:91:E6:6E:D1:1E
inet addr:192.168.225.1 Bcast:192.168.225.255 Mask:255.255.255.0
inet6 addr: fe80::6091:e6ff:fe6b:ce1b/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:1 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:76 (76.0 B)
ecm0 Link encap:Ethernet HWaddr 92:A7:8F:16:37:63
inet addr:192.168.2.2 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::90a7:8fff:fe16:3763/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4907 errors:0 dropped:0 overruns:0 frame:0
TX packets:2868 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:5081799 (4.8 MiB) TX bytes:363958 (355.4 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1 errors:0 dropped:0 overruns:0 frame:0
RX bytes:76 (76.0 B) TX bytes:76 (76.0 B)
rmnet0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING MTU:2000 Metric:1
TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:108 (108.0 B) TX bytes:432 (432.0 B)
rmnet_data0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet6 addr: fe80::a816:2ace:e10:453d/64 Scope:Link
inet6 addr: 240a:d:4844:bd20:71c6:a5c3:47b2:655a/64 Scope:Global
UP RUNNING MTU:1500 Metric:1
RX bytes:104 (104.0 B) TX bytes:432 (432.0 B)
rmnet_data1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
[NO FLAGS] MTU:1500 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
rmnet_data2 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_data3 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_data4 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_data5 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_data6 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_data7 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
