Any news on this? I have been trying to get SPI1 running now for a while on my WP85. SPI1_MOSI and SPI1_SCK looks OK on scope but I cannot set the SPI1_MRDY pin which I use as a slave select to my SPI slave. See my code snippets below.
#include "legato.h"
#include "interfaces.h"
#include <stdint.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <getopt.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/types.h>
#include <linux/spi/sierra_spidev.h>
#define SPI_CPHA 0x01
#define SPI_CPOL 0x02
#define SPI_MODE_0 (0|0)
#define SPI_MODE_1 (0|SPI_CPHA)
#define SPI_MODE_2 (SPI_CPOL|0)
#define SPI_MODE_3 (SPI_CPOL|SPI_CPHA)
#define SPI_CS_HIGH 0x04
#define SPI_LSB_FIRST 0x08
#define SPI_3WIRE 0x10
#define SPI_LOOP 0x20
#define SPI_NO_CS 0x40
#define SPI_READY 0x80
#define SPI_TX_DUAL 0x100
#define SPI_TX_QUAD 0x200
#define SPI_RX_DUAL 0x400
#define SPI_RX_QUAD 0x800
* DEFINES
#define FAIL_ON_ERROR(expr) do { le_result_t _result_ = (expr); LE_FATAL_IF(_result_ < 0, #expr " failed with %d", _result_); } while (0)
* DEFINITIONS
#define ARRAY_SIZE(a) (sizeof(a) / sizeof((a)[0]))
static le_timer_Ref_t spiTimer; ///< Timer for spi reading
static const le_clk_Time_t spiTimerTime = { .sec = 2, .usec = 0 }; ///< Time between data monitor ticks
static void pabort(const char *s)
LE_FATAL(s);
int32_t spiFd;
static const char *device = "/dev/nrfPort";
static uint8_t mode;
static uint8_t bits = 8;
static uint32_t speed = 960000;
static uint16_t delay = 10;
static uint8_t length=16;
static uint8_t pattern[16] = {0xA0,0xA1,0xA2,0xA3,0xA4,0xA5,0xA6,0xA7,
0xA8,0xA9,0xAA,0xAB,0xAC,0xAD,0xAE,0xEF};
static uint32_t order;
static void transfer(int fd)
int i,ret;
uint8_t *tx;
uint8_t *rx;
struct spi_ioc_transfer tr;
memset(&tr, 0, sizeof(tr));
tr.tx_buf = 0;
tr.rx_buf = 0;
tr.len = length;
tr.delay_usecs = delay;
tr.speed_hz = speed;
tr.bits_per_word = bits;
tr.cs_change = true;
/* create tx & rx buffers */
tx=calloc(sizeof(uint8_t),length);
rx=calloc(sizeof(uint8_t),length);
for (i=0;i<length-1;i+=ARRAY_SIZE(pattern))
if ((i+ARRAY_SIZE(pattern)) > length)
memcpy(tx+i,pattern,length-i);
else
memcpy(tx+i,pattern,ARRAY_SIZE(pattern));
tr.tx_buf=(unsigned long)tx;
tr.rx_buf=(unsigned long)rx;
ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr);
if (ret < 1)
pabort("can't send spi message");
for (ret = 0; ret < length; ret++) {
if (!(ret % 8))
LE_INFO(" ");
LE_INFO("%.2X ", rx[ret]);
LE_INFO(" ");
* Timer handler for spi update
static void spiTimerHandler(le_timer_Ref_t timerRef)
(void)timerRef;
//send some dummy data
transfer(spiFd);
LE_DEBUG("spiTimerHandler: expired %d", le_timer_GetExpiryCount(timerRef));
COMPONENT_INIT
int ret = 0;
LE_INFO("spiReader:Init");
spiFd = open(device, O_RDWR);
if (spiFd < 0)
pabort("can't open device");
* spi mode
mode = 0;
mode |= SPI_MODE_2;
//mode |= 0x20; //SPI_LOOP
ret = ioctl(spiFd, SPI_IOC_WR_MODE, &mode);
if (ret == -1)
pabort("can't set spi mode");
ret = ioctl(spiFd, SPI_IOC_RD_MODE, &mode);
if (ret == -1)
pabort("can't get spi mode");
* bits per word
bits = 8;
ret = ioctl(spiFd, SPI_IOC_WR_BITS_PER_WORD, &bits);
if (ret == -1)
pabort("can't set bits per word");
ret = ioctl(spiFd, SPI_IOC_RD_BITS_PER_WORD, &bits);
if (ret == -1)
pabort("can't get bits per word");
* max speed hz
speed = 960000;
ret = ioctl(spiFd, SPI_IOC_WR_MAX_SPEED_HZ, &speed);
if (ret == -1)
pabort("can't set max speed hz");
ret = ioctl(spiFd, SPI_IOC_RD_MAX_SPEED_HZ, &speed);
if (ret == -1)
pabort("can't get max speed hz");
LE_INFO("spi mode: %d\n", mode);
LE_INFO("bits per word: %d\n", bits);
LE_INFO("max speed: %d Hz (%d KHz)\n", speed, speed/1000);
LE_INFO("LSB first\n");
spiTimer = le_timer_Create("SPI_TIMER");
FAIL_ON_ERROR( le_timer_SetHandler(spiTimer, spiTimerHandler));
FAIL_ON_ERROR( le_timer_SetInterval(spiTimer, spiTimerTime));
FAIL_ON_ERROR( le_timer_SetRepeat(spiTimer, 0));
FAIL_ON_ERROR( le_timer_Start(spiTimer));
//close(spiFd);
