SPI problem
Hi
I am trying to set up spi for an LCD that I am using, the communication is thus only one way.When I subscribe to the SPI and write to it, the result is correct but when I try to measure the clock or anything with an ossiloscope, there is only noise. Is there something i missed? I attached the code to make it more clear. I am using pin 19 as the chip select.
Any help would be much appreciated.
#include "adl_global.h"
const u16 wm_apmCustomStackSize = 1024 * 3;
#define OUTPUT_PIN 19
adl_busAccess_t busAccessMode = { 0x00, 0x00 };
s32 busSubscribeHandle;
s32 MyGpioHandle2;
adl_ioDefs_t PIN_DESCRIP2 = ADL_IO_GPIO | OUTPUT_PIN | ADL_IO_DIR_OUT;
void SPI_Write(u8 *Data, int DataLenghts) {
	s32 adl_busWriteAnswer;
	TRACE((2,"Write"));
	TRACE((2,(ascii *)Data));
	adl_ioWriteSingle(MyGpioHandle2, &PIN_DESCRIP2, TRUE);
	adl_busWriteAnswer = adl_busWrite(busSubscribeHandle, &busAccessMode, 10,
			Data);
	TRACE((2,"Result %d",adl_busWriteAnswer));
	//adl_ioWriteSingle(MyGpioHandle2, &PIN_DESCRIP2, FALSE);
void MyTimerHandler(u8 Id, void * Context) {
	u8 *buffer;
	buffer = (u8 *) adl_memGet(10);
	wm_memset(buffer, 0xFF, 8);
	buffer[8] = 0x00;
	buffer[9] = 0x00;
	SPI_Write(buffer, 10);
	adl_memRelease(buffer);
void adl_main(adl_InitType_e InitType) {
	TRACE (( 1, "Embedded Application : Main" ));
	u32 spiHandle = 1;
	u32 Datasize = 8;
	u32 Bussize = 8;
	u32 Opsize = 8;
	s32 adl_busIOCtlAnswer;
	adl_busSPISettings_t MySpiconfig = { 12, ADL_BUS_SPI_CLK_MODE_0,
			ADL_BUS_SPI_ADDR_CS_NONE, ADL_BUS_SPI_CS_POL_HIGH,
			ADL_BUS_SPI_MSB_FIRST, 0, ADL_BUS_SPI_LOAD_UNUSED,
			ADL_BUS_SPI_DATA_UNIDIR, ADL_BUS_SPI_MASTER_MODE,
			ADL_BUS_SPI_BUSY_UNUSED };
	busSubscribeHandle = adl_busSubscribe(ADL_BUS_ID_SPI, spiHandle,
			&MySpiconfig);
	MyGpioHandle2 = adl_ioSubscribe(1, &PIN_DESCRIP2, 0, 0, 0);
	TRACE((2,"result: %d", busSubscribeHandle));
	switch (busSubscribeHandle) {
	case OK:
		TRACE((2, "OK"));
		break;
	case ADL_RET_ERR_PARAM:
		TRACE((2, "ADL_RET_ERR_PARAM"));
		break;
	case ADL_RET_ERR_ALREADY_SUBSCRIBED:
		TRACE((2, "ADL_RET_ERR_ALREADY_SUBSCRIBED"));
		break;
	case ADL_RET_ERR_BAD_HDL:
		TRACE((2, "DL_RET_ERR_BAD_HDL"));
		break;
	case ADL_RET_ERR_NOT_SUPPORTED:
		TRACE((2, "ADL_RET_ERR_NOT_SUPPORTED"));
		break;
	case ADL_RET_ERR_SERVICE_LOCKED:
		TRACE((2, "ADL_RET_ERR_SERVICE_LOCKED"));
		break;
	adl_busIOCtlAnswer = adl_busIOCtl(busSubscribeHandle,
			ADL_BUS_CMD_SET_ADD_SIZE, &Bussize);
	TRACE((2,"result: %d", adl_busIOCtlAnswer));
			ADL_BUS_CMD_SET_DATA_SIZE, &Datasize);
			ADL_BUS_CMD_SET_OP_SIZE, &Opsize);
	TRACE((2,"SPI init complete"));
	adl_tmrSubscribe(TRUE, 20, ADL_TMR_TYPE_100MS, MyTimerHandler);
	// TO DO : Add your initialization code here
