How to set custom APN?
Hi, I am working with RC7620. I am trying to set APN using at+cgdcont. The command seems to work as such, in terms of allowing me to set APN of choice, but when I set a wrong APN also, I seem to get a valid IP and data connection, which seems strange. I tried at!reset afterwards, but it still works. Am I missing something for APN setting? I have a ‘tre’ SIM whose APN is data.tre.se.
at+cgdcont?
+CGDCONT: 1,“IP”,“WRONGAPN”,“0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“sos”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1
ati
Model: RC7620
Revision: SWI9X07H_00.08.19.00 725c0e jenkins 2021/09/08 14:36:45
IMEI: 353634110232963
IMEI SV: 18
FSN: 7Q1376000302B0
+GCAP: +CGSM
echo at+cops? | socat - /dev/ttyUSB2,raw,echo=0,crnl,b115200
at+cops?
+cops: 0,0,“3”,7
/ # ip a show wwan0
4: wwan0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc fq state UNKNOWN group default qlen 1000
link/none
inet 79.138.249.44/29 brd 79.138.249.47 scope global wwan0
valid_lft forever preferred_lft forever
/ # ping -c 4 www.google.com
PING www.google.com (142.250.74.132): 56 data bytes
64 bytes from 142.250.74.132: seq=0 ttl=57 time=38.938 ms
64 bytes from 142.250.74.132: seq=1 ttl=57 time=38.603 ms
64 bytes from 142.250.74.132: seq=2 ttl=57 time=31.227 ms
64 bytes from 142.250.74.132: seq=3 ttl=57 time=38.115 ms
— www.google.com ping statistics —
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 31.227/36.720/38.938 ms
this may depend on the network operator whether wrong APN can establish data connection
Ok, but is this the right way to set APN in RC76xx ?
at+cgdcont=1,“IPV4V6”,“data.tre.se”
And does it require a modem reboot after setting APN?
yes.
Normally I will do a reboot after setting APN.
OK. When we don’t set any APN (leave it empty), how to know which APN is being used by the modem? Is there a way to query what APN is configured? If nothing is set using at+cgdcont, it shows empty when queried also. So it is not clear where the configuration is stored in the modem and how to retrieve that information.
I think it would use empty APN to communicate with network
Hi @saim,
in that particular context you can query the APN with AT+CGCONTRDP=1.
Regards,
Reinhard
Thank you for your quick response. What I set with at+cgdcont is being read by at+cgcontrdp. When I set it to empty with at+cgdcont, I can now read the actual APN being configured. But when I set it to anything else, a different valid IP is assigned and the data connection still works, though the APN is wrong. This is a bit confusing.
/ # echo at+cgdcont=1,"IP","WRONGAPN" | socat - /dev/ttyUSB2,raw,echo=0,crnl,b115200
at+cgdcont=1,“IP”,“WRONGAPN”
/ # echo at+cgdcont? | socat - /dev/ttyUSB2,raw,echo=0,crnl,b115200
at+cgdcont?
/ # echo AT+CGCONTRDP=1 | socat - /dev/ttyUSB2,raw,echo=0,crnl,b115200
AT+CGCONTRDP=1
+CGCONTRDP: 1,5,WRONGAPN,2.71.21.117,80.251.201.177,80.251.201.178
/ # ip a show wwan0
link/none
inet 2.71.21.117/30 brd 2.71.21.119 scope global wwan0
PING www.google.com (216.58.211.4): 56 data bytes
64 bytes from 216.58.211.4: seq=0 ttl=60 time=40.920 ms
64 bytes from 216.58.211.4: seq=1 ttl=60 time=38.455 ms
64 bytes from 216.58.211.4: seq=2 ttl=60 time=38.206 ms
64 bytes from 216.58.211.4: seq=3 ttl=60 time=37.820 ms
round-trip min/avg/max = 37.820/38.850/40.920 ms
