I have a question about file transfer from ORP to remote asset.
How to I do this I can’t find the document about ORP send files to remote device by RS232 to serial USB?
You can find the information on the online help.
Hi @djudkins ,
Thanks for your reply,
I already find the online help, but I can’t open “ORP and File Transfer Overview”.
And I find other help like Sending Files to your Asset
I want to do step 3, but I have no idea.
Can you help me how to do this? (My device is FX30s and use RS232 to usb)
Hello Larry,
I also got the 404 error, we will correct this ASAP., Thanks for this post!
Larry,
You can get to the problematic link here:
Hi @djudkins ,
I study the link Octave Resource Protocol Reference Guide
but I still understand how to do it (Send file from Octave to Remote device: like ubuntu)
Does it have a sample to do this ?
Octave send to remote asset?
Hello Larry,
The send file is documented here
Here is a complete file transfer tutorial with sample code
If you wish to use the Octave APIs instead of the Octave UI, the API tutorial is here:
Hi @djudkins ,
Thanks for your reply, I already read these documents, and I also download GitHub - SierraWireless/octave-orp: Octave Resource Protocol
And I try to use the ORP to download file to my Ubuntu.
I want to download file from Octave and the file I upload by Octave dash board.
So I can see the file in /files/list, like below
How can I download the file to my Ubuntu?
I want to download the file to my PC. Please help me thanks…
Hi Larry,
Have you implemented the ORP file transfer code on your Ubunto?
This is a part of Step 3
and described in detail in the following link
and more specifically
Hi @djudkins ,
How should I do it and what API should I use Edge Action?
Like this ?
I can use it and create, add handler, get or set.
But it cannot download the file like below and the file path is “/data/le_fs/fileStream/files”:
Do you have any examples in edge action that I can refer to?
Q2. I have a question about file transfer?
Following the flow like below:
The first step is “SYN” and how do I send the command
“$ orp> sync syn XX”
How could I get file info with what command ?
If I want to get file size how do I get the value?
Q3. When I use “file control ready” and “file control start -a ” and my file looks locked
Do I lose finished command for unlock file?
Hi @djudkins ,
Thanks for your reply.
I have looked the video and have some questions
How can I get sync packet
The document says every 5 sec will receive sync packets
But in my case I can’t see the information.
And sometimes I can’t get response.
So my question is “How could I check the client is connected to server in ORP?”
