How to run an app on localhost
#1
Hi evreybody,
I’m trying to install legato on my linux ubuntu, and i’d like to test demo’s apps (HelloWorld) on localhost before usie target, but i don’t find commands to run it .
i tried instapp myapp localhost, it doesn’t work. the same for startapp myapp localhost.
i have tried to start legato on localhost with startlegato, but i don’t find the commande to run the app.
Would you please give me some suggestion to solve this problem?
Thank you.
#2
Here’s an example of how you can run the sample helloWorld app on localhost:
  1. Build legato for localhost
    make localhost
  2. Source legato environment
    bin/legs
  3. Run ‘startlegato’ script from bin directory.
    ./bin/startlegato
  4. Go to apps/sample/helloWorld and build helloWorld for localhost
    cd apps/sample/helloWorld make localhost
  5. When app is successfully built, go to _build_helloWorld/localhost/staging/bin and run binary.
    [code]
    cd _build_helloWorld/localhost/staging/bin
    ./helloWorld
    Apr 7 11:40:02 : -WRN- | serviceDirectory[30082]/framework T=main | mem.c le_mem_ForceAlloc() 679 | Memory pool ‘refFdMonitors’ overflowed. Expanded to 10 blocks.
    Apr 7 11:40:02 : INFO | helloWorld[30137]/helloWorld_exe T=main | helloWorld.c _helloWorld_exe_COMPONENT_INIT() 5 | Hello, world.
    [/code]
Also you can stop the localhost version of legato by running ‘bin/stoplegato’.
Enoch
#3
It works ! :smiley:
Thank you ! :slight_smile:
#4
Im trying to do the same with Legato 18.04.0
bin is not getting created after following the mentioned steps.
this fails
and creates
legato/apps/sample/helloWorld/_build_helloWorld/localhost/staging/read-only/lib/libComponent_helloComponent.so
Can anybody help?
#5
Its working fine. Thanks for post
#6
Hey Can I know versions you are using ?
