How to RC7630 Rx on/off control
Please check if it is possible to control the RX ON/OFF of the main antenna.
Checked via RC7630 AT command manual, I checked the AT command manual, but RX on/off of the Main antenna is not described.
please help us.
You can put module into shielding box instead.
BTW, why don’t you put module into flight mode if you want to put RX OFF?
Customer wants to control RX via AT command (only TX used)
Can’t RX be turned ON/OFF with AT command?
If you just turn off RX and turn on RX, what do you expect for module?
Testing TX power?
have you tried those factory test command AT!DA?
I saw there is command to control TX power
