I have gotten the Wavecom modem with the TCP/IP stack, now I need to know if I can get the files from an FTP site… I am running it from the terminal emulator that comes with OpenAT. If I get the file from a FTP server where is it stored?
Solved, commands were entered wrong…
Hi Samuel:
I am asking the same question u asked one year ago:
[color=red] If I get the file from a FTP server where is it stored?
I hope u got the answer?
Surely, if you get it, then it is stored to wherever you asked for it to be stored?
Thank u for the reply. This is true when u write your own application where u can define your buffer, event handler…etc
I used the WIP sample FTP as the document says I used:
[color=brown]at+wipftp=0,port,mode,“type”,“server”,“login”,“password”,“path”,“file” to retrieve a file from the server.
I can’t see how to define a storage using at+wip command. It is not mentioned in the document.
at+wip commands won’t let you store anything on the module. It will send the file content, as escaped data, on the UART on which you sent the at+wip command. If you use the SDK’s terminal emulator, it will be dumped on the “data” sub-window.
Notice that what’s sent is escaped: characters \10 are escaped as \10\10, and \3 as \10\3. A non-escaped \3 character marks the end of file.
