Hi guys,
Stumbled upon HL8549 on the documents section.
May I what is the differences between HL8548 & HL8549?
Thank you.
Hi guys,
Thank you.
Hi phangmoh,
I think the feature is the same except HL8548 uses conformal coating but HL8549 comes with traditional shield can.
The physical dimensions is different, HL8549 is bigger in around 1mm so doesn’t fit the snap in socket.
Hope it helps.
Thx
Thank you for the explanation.
I just received my samples of HL854 and noticed what you have mentioned, the conformal coating!
This would mean it will be easier for reflow process if I’m correct? Was having a tough time reflowing when using a WISMO228 which came with the metal shield.
