I tested HL7810 on Eval board HL78-R3 and I have over consumption during hibernate mode after second being.
The last firmware version as been updated:
HL7810.5.7.2.0-24.10.0.FreeRTOS.w43
HL78xx.5.7.2.0.RK_03_02_00_00_43621_001.20241029
IMEI-SV: 3547205115610420
Legato RTOS: 24.10.0.FreeRTOS.w43 2024/09/18 16:49:33
atSwi: 24.10.0.FreeRTOS.w43
UBOOT: 01.03
Apps: RKAPP_03_02_00_00_42831_012__a9591ae8197c6856cd9bbe5e66be200d0d05acac
MAC: ALT1250_03_02_00_00_43621_FW
PHY: 12.50.329298
PMP: 329207
AISE: ISE2APP_00_00_00_09
SBUB: 1
SBFW: 1
FPuK1: 1B993663
FPuK2: 25DF28C5
RBUB: 0
RBFW: 0
MCU-Disable: 1
I removed jumpers CN1310, CN1308, CN1309 and CN1301 (pin1-2) as recommended in “3.1.4 Module Current Consumption Meas” chapter.
I connected a power supply OTTI ARC on CN804 and CN800 to measure the consumption.
USB cable is connected on UART1 connector.
I configured the hibernate mode with following command: “AT+KSLEEP=1,2,10”
=> read response “AT+KSLEEP?” => +KSLEEP: 1,2,10
I configured the PSM mode with following command: “AT+CPSMS=1”
=> read response “AT+CPSMS?” => +CPSMS: 1,“00101100”,“00001010”
The provided SIM with eval board is inserted in SIM connector.
The Eval board is powered off and WAKE UP switch on ON position
Here are the following actions done:
- Power up of OTTI ARC at 3.6V on CN804 and CN800
- Wait 30 seconds
- “AT+CFUN=0” command and next configure WAKE UP switch on OFF position (WAKEUP = 0) and consumption is around 2.72 µA as shown below:
- WAKE UP switch on ON position
- command AT+CFUN=1
- wait around 14 seconds
- command AT+CFUN=0 and next configure WAKE UP switch on OFF position and the consumption is around 28.5 µA as shown as below:
Can you help me to analyze this issue and understand how I can have always 2.8 µA consumpation each time the module goes to hibernate mode
