Is there a place where i can find the Firmware images that are on the devices when they are shipped?
i believe they were version 1.7.14 .
I had a working setup using this firmware but after upgrading to 2.3.1 or 2.5.1 i encountered some problems and would like to go back to the original firmware to confirm the code before i start debugging.
Is there a place with all the images and maybe some release notes detailing the differences between versions ?
Hi Thomas.
That was the first place where i looked.
And for most other modules there are indeed firmware images.
But for the HL7800 i can not find anything
on the device page nor by searching for the model number under resources.
HI @slenders,
1.7.x firmware baseline is quite old and no longer supported. I would recommend to stay with latest 2.5.x baseline. If you are having issues with 2.5.x baseline, please report them and Sierra team can try to help.
Where do you get your firmware releases from?
we received our modules with FW 1.7.14 on the reel.
Our client provided us with FW versions 2.3.1 , 2.5.1 and 1.7.12
Im using the Devkit 5303247 rev4 . connected wit a coax to a CMW500 Radio tester. together with a test sim
the virgin module works .
if i upgrade it to 2.3 or 2.5 the module tries to attach, i get a signaling failure on my cmw and the UE disconnects.
I dont have the original FW. But if i downgrade this module to 1.7.12. I again get a working connection.
i have attached a log with detailed FW versions if it helps.
Do have any idea wat can cause this behaviour? any commands i can use to further investigate this?
