Could a kind person that has the HL7692 V2.26 firmware, send to me (eg via WeTransfer) ?
The installer .exe, and the Xmodem file, if you could. Filenames and sizes likely as below, or similar.
Yes, not the latest, V2.27. Don’t ask ! Email address david_dot_king_at_sensium_dot_co_dot_uk
If your tried emailing me, but it bounced, it could be because our email system doesn’t accept exe attachments.
www.wetransfer.com is super easy for sending any files, especially big ones
Or the other method I use, a bit less easy, is using 7-Zip, zip files with password of password. Then do the same again. That way, exe files can be sent via email.
Thanks once again Donald for helping me out with the V2.26 firmware. Please send exe installer, and dwl file
Must be I’m misunderstanding something, as you wrote my correct email address in your earlier reply, and I confirmed it was correct. Per your request though, kindly find below my email address, screengrabbed.
The filename for the second was kind of interesting, I was expected something more like the below. Is the above file OK for programming via UART, as well as via FOTA ?
