Hello everyone,
I’m trying to integrate android 9 ril software into my Android 9. The kernel I’m using is 4.14.98.
HL7692 modem firmware was updated to 2.27.
On my android device the modem is connected via USB OTG.
The SIM works fine on other devices. All works fine, mobile network with 4G is working.
But i can’t unlock the SIM on the Android Lockscreen:
02-03 15:52:19.295 E/use-Rlog/RLOG-RIL( 2927): processRequest: ENTER_SIM_PIN
02-03 15:52:19.295 I/use-Rlog/RLOG-AT( 2927): --- AT+CPIN="3603",""
02-03 15:52:19.295 I/use-Rlog/RLOG-AT( 2927): AT(12)> AT+CPIN="3603",""
02-03 15:52:19.299 I/use-Rlog/RLOG-AT( 2927): AT(12)< +CME ERROR: 4
02-03 15:52:19.299 I/use-Rlog/RLOG-AT( 2927): --- AT+XPINCNT
02-03 15:52:19.300 I/use-Rlog/RLOG-AT( 2927): AT(12)> AT+XPINCNT
02-03 15:52:19.320 I/use-Rlog/RLOG-AT( 2927): AT(12)< +XPINCNT: 3,3,10,10
02-03 15:52:19.320 I/use-Rlog/RLOG-AT( 2927): AT(12)< OK
02-03 15:52:19.320 E/RILC ( 2927): supplyIccPinForAppResponse: amit ret 3
02-03 15:52:19.321 D/RILJ ( 3336): ON some errors fakeSimStatusChanged: reg count=1 [SUB0]
02-03 15:52:19.321 D/RILJ ( 3336): [3789]< ENTER_SIM_PIN error 2 [SUB0]
02-03 15:52:19.321 D/RilRequest( 3336): [3789]< ENTER_SIM_PIN error: com.android.internal.telephony.CommandException: GENERIC_FAILURE ret={3}
02-03 15:52:19.322 D/UiccController( 3336): Received EVENT_ICC_STATUS_CHANGED, calling getIccCardStatus
02-03 15:52:19.323 D/RILJ ( 3336): [3790]> GET_SIM_STATUS [SUB0]
02-03 15:52:19.323 D/UiccCardApplication( 3336): parsePinPukErrorResult: attemptsRemaining=3
02-03 15:52:19.323 E/use-Rlog/RLOG-RIL( 2927): processRequest: GET_SIM_STATUS
02-03 15:52:19.323 I/use-Rlog/RLOG-AT( 2927): --- AT+CPIN?
02-03 15:52:19.323 I/use-Rlog/RLOG-AT( 2927): AT(12)> AT+CPIN?
02-03 15:52:19.328 I/use-Rlog/RLOG-AT( 2927): AT(12)< +CPIN: SIM PIN
02-03 15:52:19.328 I/use-Rlog/RLOG-AT( 2927): AT(12)< OK
02-03 15:52:19.328 D/RILJ ( 3336): IccCardApplicationStatus 0:{APPTYPE_SIM,APPSTATE_PIN} [SUB0]
02-03 15:52:19.328 D/RILJ ( 3336): responseIccCardStatus: from HIDL: IccCardState {CARDSTATE_PRESENT,PINSTATE_UNKNOWN,num_apps=1,gsm_id=0{APPTYPE_SIM,APPSTATE_PIN},cdma_id=-1,ims_id=-1,physical_slot_id=-1,atr=null,iccid=null} [SUB0]
02-03 15:52:19.329 D/RILJ ( 3336): [3790]< GET_SIM_STATUS IccCardState {CARDSTATE_PRESENT,PINSTATE_UNKNOWN,num_apps=1,gsm_id=0{APPTYPE_SIM,APPSTATE_PIN},cdma_id=-1,ims_id=-1,physical_slot_id=-1,atr=null,iccid=null} [SUB0]
02-03 15:52:19.329 D/UiccController( 3336): Received EVENT_GET_ICC_STATUS_DONE
02-03 15:52:19.330 D/UiccSlot( 3336): cardStatus update: IccCardState {CARDSTATE_PRESENT,PINSTATE_UNKNOWN,num_apps=1,gsm_id=0{APPTYPE_SIM,APPSTATE_PIN},cdma_id=-1,ims_id=-1,physical_slot_id=-1,atr=null,iccid=null}
02-03 15:52:19.330 E/AnswerToReset( 3336): The input ATR string can not be null
02-03 15:52:19.330 D/UiccSlot( 3336): update: radioState=RADIO_ON mLastRadioState=RADIO_ON
02-03 15:52:19.330 D/UiccProfile( 3336): 1 applications
02-03 15:52:19.330 D/UiccCardApplication( 3336): APPTYPE_SIM update. New {APPTYPE_SIM,APPSTATE_PIN}
02-03 15:52:19.330 D/UiccProfile( 3336): Before privilege rules: Handler (com.android.internal.telephony.uicc.UiccCarrierPrivilegeRules) {534c2e2} : CARDSTATE_PRESENT
02-03 15:52:19.331 D/UiccProfile( 3336): setExternalState: !override and newstate unchanged from PIN_REQUIRED
02-03 15:52:19.331 D/UiccController( 3336): Notifying IccChangedRegistrants
02-03 15:52:19.331 D/GsmSMSDispatcher( 3336): GsmSMSDispatcher: subId = 1 slotId = 0
02-03 15:52:19.332 D/SIMRecords( 3336): [SIMRecords] getServiceProviderName: no brandOverride, providerName=null
02-03 15:52:19.332 D/SST ( 3336): [0] updateSpnDisplay: radio is on but out of service, set plmn='Nur Notrufe'
02-03 15:52:19.333 D/CAT ( 3336): CatService: handleMessage[8]
02-03 15:52:19.333 D/CAT ( 3336): CatService: MSG_ID_ICC_CHANGED
02-03 15:52:19.333 D/CAT ( 3336): CatService: New Card State = CARDSTATE_PRESENT Old Card State = CARDSTATE_PRESENT
CME Error 4: Operation not supported
I can unlock the SIM manually with busybox microcom when sending AT+CPIN="3603"
Why does the RIL uses AT+CPIN="","" when AT+CPIN="" is correct?
- Is the vendor RIL from Sierra sending this command?
- So i can’t do anything, except using a different binary?
- Can i change anything in my android?
- Do I miss some further settings/properties?
However, if no SIM PIN is set, using the SIM card is possible. I can also set a new PIN in the Android settings.
Also: When using the WP7607 with the QMI vendor RIL, unlocking the SIM was no problem. That’s why i think the vendor RIL from Sierra messes some things up here.
getrprop:
[gsm.network.type]: [Unknown]
[gsm.operator.alpha]: []
[gsm.operator.iso-country]: []
[gsm.operator.isroaming]: [false]
[gsm.operator.numeric]: []
[gsm.sim.operator.alpha]: []
[gsm.sim.operator.iso-country]: []
[gsm.sim.operator.numeric]: []
[gsm.sim.state]: [PIN_REQUIRED]
[gsm.version.baseband]: [RHL769x.2.27.183100.201809071813.x7120m_3]
[gsm.version.ril-impl]: [Sierra Ril V9.0.4.0_ARM_64 HL]
[init.svc.ril-daemon-hl]: [running]
[persist.sierra.sim_ready_delay]: [0]
[persist.sys.ril.type]: [HL]
[ro.boottime.ril-daemon-hl]: [7686735125]
[ro.radio.noril]: [no]
[ro.ril.wake_lock_timeout]: [300]
[telephony.lteOnCdmaDevice]: [0]
[telephony.lteOnGsmDevice]: [1]
I also tested with different values for sim_ready_delay, but that changed nothing as expected.
Anyone running the HL7692 or some similar modem successfully in Android?
Thanks in advance!
