HL7588 AT Latency & Throughput
Hello! I am using a HL7588 modem over Serial UART , 115200 baud (firmware RHL75xx.V.3.15.151600.201802071640.x7160_1) . I’ve noticed I’m having particularly slow configuration and responses over the uart. Each AT command is taking quite a while for configuration and to receive a response. For instance, these following timing for AT commands is common place:
AT+KUDPCFG: 112-285+ ms
AT+KUDPSND: 7-12ms
EOF-MARKER: ~128ms
AT+KUDPCLOSE: 12ms
With these timings, it can take me over 400ms just to get the UDP overhead accomplished (plus the actual transmit time for the data I’m sending).
Two questions:
  1. is this normal, or did I get a defective modem?
  2. how can I speed this up over serial?
I’m using as Teensy 3.6 to configure the modem. I need to use a small embedded device upstream of the modem, so that rules out adding PPP etc over USB. Is there a way to optimize this so I can send a single packet in less than 1/2 of a second over UART?
Things I’ve tried:
  • I am using hardware control flow.
  • I tried setting up “warm” UDP contexts so I could cut out the KUDPCFG overhead, but to send to another context, I still have to close the previously used context.
  • I’ve adjusted the baud rates to higher rates in common between the Teensy and Modem. However, this only shaved a couple (less than 10) ms off total times.
Any insight or recommendations from anyone would be greatly appreciated!
Thanks!
It’s normal you get around 400ms to get the above UDP accomplished.
I got the similar timing as you in my HL dev-kit even with USB IF connected with my PC.
It seems cannot speed up much even with good signal, high UART baudrate.
Thank you for letting me know! I was starting to think I was missing something.
Thanks!
