I left GPIO3 unconnected(left open) on the HL7539 in the board I designed.
In that case, would it be okay to disable the SIM detect setting?
If the SIM detect setting is enabled, what kind of problems would be noticed?
Best Regard
Best Regard
I saw that you can disable sim detect with +KSIMDET command, you can make a trial on that command.
why do you still enable SIM detect if you have left GPIO3 opened?
Thank you for your response.
Is +KSIMDET: saved in non-volatile memory over module reboot?
