I’m using the HL8549 module and I would like disable the automatic register.
Can anybody help me?
Thanks.
Thanks.
I presume you do not want it to attach to a unit on power up? You could set it to manual network selection prior to power down i.e. at+cops=1,2,“00101”.
Hi Matt,
Thank you for replying.
When I power on the module, I automatically get:
I would like to disable the SIM select and network register on module/firmware startup.
Follow my results:
at+cops=1,2,"00101"
I didn’t receive a response.
at+cops=1,2,“00101”,2
at+cops?
+COPS: 1
Unfortunately still remains with the same behavior.
It was a workaround, the unit will still go looking for a network but it will only attempt to attach to a network with MCC/MNC 00101 which it will never find, at this point, because the unit is powered up, you can force it to low power mode with at+cfun=0 and it will stop searching. If you want to then send it off searching automatically you can send at+cops=0 (then take it out of LPM with at+cfun=1).
Otherwise there is no way to power up in LPM only to not search for networks.
