I have been trying to get the Developer Studio and Open AT libraries to install for over 3 hours now and its still not finished adding the repositories.
I was unable to confirm if this module can be used with OpenAT libraries from the data sheet too (I did not read every page, just searched)
Can somebody confirm if Open AT library could be used with HL6528 and also on a PIC32 as the host.
OK, that said, are there are some libraries for host MCUs similar to the Open AT Library to handle tasks like issuing AT commands, wait for response, compare with the expected positive and negative responses?
I dont want to reinvent the wheel is there is something already available.
I believe it is relevant in this forum. Reference to such a library in this forum would help speed up the development for the guys using the HL devices.But developers such as myself can greatly benefit if there is reference to such a library from the collective experience of the forum.
I understand this forum is not intended for MCU related questions, if you want to keep the forum well-organized. I looked and there is not a good AT-Cmd library that I could use directly with GSM modules.
If you are using linux and are prepared to do a little scripting, you could also look at ‘chat’ (originally designed to do at command processing inside ppp when using a dial-up modem), or if you need something a little more sophisticated, then have a look at program called ‘expect’ (wikipedia.org/wiki/Expect) which was originally used for automating interactions with interactive programs such as ftp.
Although, if you’re trying to use at commands from inside another application, neither of these are libraries.
