Hello!
How i can get the GPS accuracy value in meters on HL8548G?
When this feature will be added?
How i can transform DOP value to accuracy?
Thanks!
Hello!
Thanks!
Did you try using AT+GPSPVT command .
You can get the details of the command from the AT command guide which can be downloaded from the following link
https://source.sierrawireless.com/resources/airprime/software/airprime_hl6_and_hl8_series_at_commands_interface_guide/
Thanks & Regards,
Rex
I read AT-command manual before writing the post.
This command haven’t information about a GPS accuracy.
This MODULE not provide information about a GPS accuracy.
But i need it.
Are you can added this features in new firmware version? Because the filtration of location data without accuracy not very correct and for HL8548 this is necessary.
Take a look at +GPSCONF or +GPSCONF? to get the values.
To set the accuracy look at config type 11 and the values for configVal1 and ConfigVal2
Thanks! I will try change the values)
Can I change the power consumption of the GPS receiver in RUNNING state(GPSCONF:0,* from 0 to 3) or not? Under what conditions can this be done?
