Help me! Where can I find the bx3105 spi communication guide?
I would like to control the mcu and bx3105 modules via spi communication, but the bx310x manual I found did not give clear instructions.
Where can I check the communication protocols and clocks needed for spi communication?
see if this helps you:
Thank you very much.!!!
But I have updated the firmware version. And I confirmed that the following text is printed.
Sierra Wireless Copyright 2018
BX310x.2.5.0-2
READY
If the above statement is output, dummy-slave-msg is not output, but after that, dummy-slave-msg is output again.
So I think there is a problem with the data transmission, but I can not solve it.
I created the data format below and sent it to for.
And stored in an array to check the return value of all the data.
typedef struct format {
byte command [CMD_MAX]; // command 2bytes
byte payloadLength [LENGTH_MAX]; // length 2 bytes
byte more; // more
byte reserved [RESERVED_MAX]; // reserved
byte payload [PAYLOAD_MAX]; // payload 256bytes
} spiFormalt;
spiFormalt protocol = {
{0x00, 0x01}, // command
{0x00, 0x03}, // payload length
0x00, // more
{0x00, 0x00, 0x00}, // reserved
{0x41, 0x54, 0x0d,} // payload
for (int i = 0; i <CMD_MAX; i ++) {
a [i] = SPI.transfer (protocol.command [i]);
delayMicroseconds (3);
As a result of checking the output, it is filled with DUMMY-SLAVE-MSG from the eighth element to the 22nd element, and the rest is output as all zeros.
I can not go on in this part anymore … Is there a good way to solve this?
What is the value of CMD_MAX, LENGTH_MAX,PAYLOAD_MAX?
From your code, you seems only send the command…
did you pull the GPIO17 to high?
did you connect SPI chip-select of BX module?
What do mean by DUMMY-SLAVE-MSG from the eighth element to the 22nd element?
Is there is any output from BX module?
Hello.
I have a problem getting an answer on spi.
All my requests are answered “DUMMY-SLAVE-MSG”.
How to send a command and receive a response in accordance with the Protocol ?
If possible, demonstrate with an example.
Thank you in advance for your help.
Hello Engineer and jyijyi
Has this problem a solution as we have exactly the same problem here.
We get the Sierra wireless reply correctly but following that we get a DUMMY-SLAVE-MSG from the BX3105 but it does not start at the beginning of the frame but some time after e.g. 15 bytes of 0 followed by the start of the frame.
Why do we not get the frame starting when the CS is selected and the clock starts?
Thank you
We have some problem too. Any commands have DUMMY-SLAVE-MSG answer. Did anybody solve it?
I referenced this document ,but just display DUMMY-SLAVE-MSG too. How can I get correct status with AT command on SPI mode?
SPI
Hi maizezoidberg,
I successful got correct response. If you still have same status, email to me.
ahwow120509@gmail.com
I approach to use the BX3105 module with SPI communication.
I was wondering if there is a detailed document were protocol commands and answers are described.
If I have not misunderstood the AT commands are transposed on SPI. Is there a specification on this?
Do you have any suggestions for me to avoid mistakes and waste of time?
Is there some code sample?
Thanks in advance
Here has the protocol:
I have tested both FW 2.6.3 and 2.7.2, it is working fine.
