BX310x Uart Communication
I just ordered this BX310x dev board, I setup the device as in the guide document; however, I am not seeing the device responding to the “ATI” command that I sent from TerraTerm. I am seeing a message when I press reset button:
"Sierra Wireless Copyright 2018
BX310x.2.6.3
READY"
This issue appears to have been mentioned many times in the forum, but no one has given a clear answer to it.
Regards,
Farid
tera term -> setup -> terminal -> newline :need to set CR , not <CR+LF>
not sure if you need to shut down the hardware flow control, you can give a try
Thank for your reply that was helpful.
Now I want to see to see BLE advertising some data. I used this command:
AT+SRBLEADV=1
I get this response.
+CME ERROR: 919
am I missing any steps before jumping this this step.
These are my configuration readings:
AT+SRBLE?
+SRBLE: “BX310x-07EF7C”,23,0,0
I tried using: AT+SRBLE=“BLE”,23,1,1. But this gives me an error.
Thank you for your help!
another command I tried is:
AT+SRBTSTATE=1,2
+CME ERROR: 919
it also gives an error
thanks
I found this thread helpful:
I am now able to see the BLE displayed on my phone BLE terminal. But I am not able to connect to it from my Iphone. I must have missed some AT configuration command.
Please advise!
