I have a customer who has embedded MC7750 modems in their laptops.
They are attempting to use our vehicle location application that requires the GPGGA and GPRMC NMEA formats.
I see the data coming into the logs, but it is the wrong format (GLGSV).
I tried using the extended AT command set but everything I have tried ends in an Error; even the most basic AT commands. So that is an issue in and of itself, as I cannot tell if I am able to talk to the modem at all… I can get a OK after a simple AT [Enter] but that is as far as it goes. It appears that the MDM9600 chipset does not support the extended AT commands, so…
Is there any way to change the sentence type via a firmware update or other commands?
Thank you!
Mary Monroe
ZOLL
