Hello everyone,
I wanted to get the GPS location via AT Commands on the AT Command Port and I could get it. But since then there always appears a log in the logread:
user.info Legato: INFO | posDaemon[834]/le_pa T=main | swiQmi.c StartService() 110 | qmi_client_get_service_list rc=-2, numServices=0
Jan 6 00:15:42 swi-mdm9x15 user.err Legato: =ERR= | posDaemon[2088]/le_pa T=main | swiQmi.c StartService() 120 | qmi_client_get_service_list time limit exceeded
Jan 6 00:15:42 swi-mdm9x15 user.err Legato: =ERR= | posDaemon[2088]/le_pa_gnss T=main | pa_gnss_qmi.c pa_gnss_Init() 741 | Could not initialize the QMI Positioning Services.
Jan 6 00:15:42 swi-mdm9x15 user.emerg Legato: EMR | posDaemon[2088]/posDaemon T=main | le_pos.c _posDaemon_COMPONENT_INIT() 646 | Failed to initialize the PA GNSS module
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | proc.c proc_SigChildHandler() 1243 | Process ‘posDaemon’ (PID: 2088) has exited with exit code 1.
Jan 6 00:15:42 swi-mdm9x15 user.crit Legato: CRT | supervisor[761]/ T=main | app.c app_SigChildHandler() 1444 | The process ‘posDaemon’ in app ‘positioningService’ has faulted and will be restarted in accordance with its fault policy.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c GetCfgResourceLimit() 181 | Configured resource limit coreDumpFileSizeLimit is not available. Using the default value 8192.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c SetRLimit() 281 | Setting resource limit coreDumpFileSizeLimit to value 8192.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c GetCfgResourceLimit() 181 | Configured resource limit maxFileSizeLimit is not available. Using the default value 90112.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c SetRLimit() 281 | Setting resource limit maxFileSizeLimit to value 90112.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c GetCfgResourceLimit() 181 | Configured resource limit memLockSizeLimit is not available. Using the default value 8192.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c SetRLimit() 281 | Setting resource limit memLockSizeLimit to value 8192.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c GetCfgResourceLimit() 181 | Configured resource limit numFileDescriptorsLimit is not available. Using the default value 256.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c SetRLimit() 281 | Setting resource limit numFileDescriptorsLimit to value 256.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c GetCfgResourceLimit() 181 | Configured resource limit totalPosixMsgQueueSizeLimit is not available. Using the default value 512.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c SetRLimit() 281 | Setting resource limit totalPosixMsgQueueSizeLimit to value 512.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c GetCfgResourceLimit() 181 | Configured resource limit numProcessesLimit is not available. Using the default value 20.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c SetRLimit() 281 | Setting resource limit numProcessesLimit to value 20.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c GetCfgResourceLimit() 181 | Configured resource limit rtSignalQueueSizeLimit is not available. Using the default value 100.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | resourceLimits.c SetRLimit() 281 | Setting resource limit rtSignalQueueSizeLimit to value 100.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[761]/ T=main | proc.c StartProc() 767 | Starting process posDaemon with pid 2118
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | supervisor[2118]/ T=main | proc.c StartProc() 744 | Execing ‘posDaemon’
Jan 6 00:15:42 swi-mdm9x15 user.warn Legato: -WRN- | posDaemon[2118]/framework T=main | mem.c le_mem_ForceAlloc() 664 | Memory pool ‘ClientThreadData’ overflowed. Expanded to 1 blocks.
Jan 6 00:15:42 swi-mdm9x15 user.warn Legato: -WRN- | posDaemon[2118]/framework T=main | mem.c le_mem_ForceAlloc() 664 | Memory pool ‘SafeRef-Map’ overflowed. Expanded to 11 blocks.
Jan 6 00:15:42 swi-mdm9x15 user.warn Legato: -WRN- | posDaemon[2118]/framework T=main | mem.c le_mem_ForceAlloc() 664 | Memory pool ‘SafeRef-Map’ overflowed. Expanded to 12 blocks.
Jan 6 00:15:42 swi-mdm9x15 user.info Legato: INFO | posDaemon[2118]/le_pa T=main | swiQmi.c StartService() 110 | qmi_client_get_service_list rc=-2, numServices=0
I don’t know how I can get rid of it. Can anyone help me? I don’t want to have these annoying logs all the time.
Thank you!
Greets,
Daniel
