Why do my Gobi kernel drivers reconnect /dev/ttyUSB0-2 on a regular basis? I have a python thread that is trying to use /dev/ttyUSB2 to send AT commands to the EM7455 and then the Gobi driver disconnects and reconnects which causes problems with my thread because the thread has that port opened. This also causes the Gobi driver to crash and output:
I could try to have my thread open the port, handles the AT commands, and then close the port but the Gobi driver might reconnect while I handle the AT command. What is the ideal protocol?
What GobiNet and GobiSerial version are you using?
Can you provide the syslog and driver diagnostic logs?
ex: echo 1 > /sys/module/GobiSerial/parameters/debug
echo 1 > /sys/module/GobiNet/parameters/debug
GobiSerial 2-1:1.3, GobiNet 2-1:1.8 (see my log below)
OK. Here is the log information below after my the GobiSerial and GobiNet disconnected and reconnected. Can you tell me how to get the Gobi stdout into a file without highlighting it with my mouse and pasting it into a text filel?
I am giving the commands to activate after a reboot/reset or power cycle using AT!SCACT=1,1 but I have to wait several minutes until I get a Sprint Connection. I use AT!LTEINFO? until I get a marginal power level from the EM7455, then I type AT!SCACT=1,1.
Please call so we can expedite these issues at 256-653-2553.
Are you working through a distributor in North America? If so, which one?
Sprint usually uses a class 3 APN requiring you to issue AT!SCACT=1,3. What does AT+CGDCONT? show?
I think you might be calling the wrong APN to start the data session. Let me also know the following:
I am confused on your answer to my “disconnect timeout question”. What AT command can I use to set my activation from timing out after 3 minutes? I want the connection valid for as long as possible.
You are misunderstanding my issue. My connection times out after 3 minutes. I don’t like this and I want to tell the software not to do that. Why does my co-worker’s EM7455 timeout at 24 hours and mine is 3 minutes? I know that Sprint will timeout my connection eventually but I want to maximize my connection time. Maybe this is caused by some other issue but I wanted to run it by you.
I am waiting to get my EM7455 re-provisioned so I can get you those command’s output that you ask for.
We will need a DM log to determine the reason for the network disconnect/timeout issue. We have a DM logging tool for Windows and one of Linux. The Linux version is located in the QMI SDK. Do you have access to the SDK? Again, where did you purchase the EM7455 module? Are you currently being supported by a Sierra Wireless FAE or technical support team?
I have the SDK and I looked at the tools/DM directory. I can now log, thanks.
./dmcapture.sh -d /dev/ttyUSB2 -l -a arm -o Mar25_DM.log
Future Electronics does not have anyone there that can handle my issues. I spoke with about 3 guys. One was suppose to be the Sierra expert but he has only been there for 4 months. The other fellows are not capable of answering my questions.
I am 6 weeks behind on my delivery. I would appreciate you sticking with me to get me past my issue.
OK, good and Future Electronics has engineers that can create a ticket to support. We need to get you to their Future Connectivity Solutions team. I will call you to discuss as they need to create a support ticket asap. What is your full name and email? Jon
Good speaking with you today. As discussed, please try connecting to the ttyUSB0 for the DM log.
Logs need to be captured as in the following example:
./dmcapture.sh –l –f filter.sqf –d /dev/ttyUSB0 –o testlog.log
You will need to use a filter (.sqf) file provided. The .dmcapture app is in the /tools/logging/dm folder in the SDK as you likely know.
Place the DM COM port after the filter file and also put the log right in the same folder as the dmcapture.sh application.
Set the module to low power mode AT+CFUN=0.
Start the dmcapture logging with filter.
Set AT+CFUN=1 Online mode.
Check AT!GSTATUS? for attach and registration (RRC, EMM…).
Reproduce the issue.
Stop the logging.
filter:
I have you contact details now and so will email our team about the support.
Here are the AT commands you asked me to perform. My IP address was not assigned correctly during this test for some reason. I am suppose to get the 10.x.x.x but I got 26.225.165.187 which is assigned DOD.
I tried to use the dm logger but nothing showed up in the output. Here is my script for the data logger:
./dmcapture.sh -d /dev/ttyUSB0 -l -a arm -o Mar28_DM.log
I suspect that nothing shows up because I have a bad IP.
Can you tell me how to resort back to a factory default on the EM7455. I want to start from scratch so I can tell the Sprint guys.
I finally received 10.x.x.x. I’m not sure why. I tried driving around in my car on the previous day near the tower but that did not work. My code works when I get the correct IP address. I’ll let you guys know if I get the wrong IP address again.
I am having problems running AT!SCACT=1,1.I get ERROR on all of my EM7455’s.
Sprint says that my issue is with the EM7455 configuration. I need your help. Why would I get ERROR when I try to create my eth1 using the Gobi kernel drivers?
I tried to get you a log file using the following but I get:
