You guys should use GobiNet for data instead of ppp (serial).
Much faster.
Here is an example to bringup data on Ubuntu (4-4-0-98) with MC7455
Same is applicable to MC73xx.
Disable modem-manager
Insert GobiNet and GobiSerial
##Plug in the modem and verify with “lsusb” that the modem is connected to the USB BUS
##This can be done even before the driver is loaded
sudo su
lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 003 Device 025: ID 1199:9071 Sierra Wireless, Inc. < ------- Sierra modem
Bus 003 Device 002: ID 5986:0295 Acer, Inc
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
##check modem enumeration with dmesg
[619215.016262] usb 3-6: new high-speed USB device number 25 using xhci_hcd
[619215.145436] usb 3-6: config 1 has an invalid interface number: 8 but max is 3
[619215.145445] usb 3-6: config 1 has no interface number 1
[619215.146071] usb 3-6: New USB device found, idVendor=1199, idProduct=9071
[619215.146080] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[619215.146085] usb 3-6: Product: Sierra Wireless MC7455 Qualcomm® Snapdragon™ X7 LTE-A
[619215.146089] usb 3-6: Manufacturer: Sierra Wireless, Incorporated
[619215.146093] usb 3-6: SerialNumber: LQ61430015021006
[619215.147481] GobiSerial 3-6:1.0: GobiSerial converter detected
[619215.147663] usb 3-6: GobiSerial converter now attached to ttyUSB0
[619215.148234] GobiSerial 3-6:1.2: GobiSerial converter detected
[619215.148446] usb 3-6: GobiSerial converter now attached to ttyUSB1
[619215.149145] GobiSerial 3-6:1.3: GobiSerial converter detected
[619215.149352] usb 3-6: GobiSerial converter now attached to ttyUSB2
[619215.150261] GobiNet 3-6:1.8 eth0: register ‘GobiNet’ at usb-0000:00:14.0-6, GobiNet Ethernet Device, e6:9a:54:59:09:2d
[619215.150628] USB Speed : USB 2.0
[619215.178947] GobiNet 3-6:1.8 enp0s20u6i8: renamed from eth0
[619231.652175] TE Flow Control Enabled
[619232.588177] creating qcqmi0
[619232.588426] RawIP mode
##Note: make sure to compile the driver with RawIP – set the makefile to rawip under GobiNet directory
##the Kernel renames the interface from eth0 to enp0s20u6i8, we have to use this interface
Login to the AT port:
microcom -p /dev/ttyUSB2 -s 115200
connected to /dev/ttyUSB2
Escape character: Ctrl-
Type the escape character followed by c to get to the menu or q to quit
ati
Model: MC7455
Revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
MEID: A000006FE803DB
ESN: 12802823658, 802B15EA
IMEI: 359072060113087
IMEI SV: 12
FSN: LQ614300150210
+GCAP: +CGSM
at!gstatus?
!GSTATUS:
Current Time: 1050 Temperature: 25
Reset Counter: 2 Mode: ONLINE
LTE band: B4 LTE bw: 15 MHz
LTE Rx chan: 2325 LTE Tx chan: 20325
LTE CA state: NOT ASSIGNED
RRC state: RRC Idle
IMS reg state: Full Srv IMS mode: Normal
PCC RxM RSSI: -55 RSRP (dBm): -84
PCC RxD RSSI: -58 RSRP (dBm): -89
Tx Power: 0 TAC: 3604 (13828)
RSRQ (dB): -10.5 Cell ID: 00D6290C (14035212)
SINR (dB): 19.4
##Note: modem is attached to the NTWK
##if not attached don’t try to bringup the data session between the host & modem
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,“vzwims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“vzwadmin”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“VZWINTERNET”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 4,“IPV4V6”,“vzwapp”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 5,“IPV4V6”,“vzw800”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 6,“IPV4V6”,“vzwclass6”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
at+cgcontrdp
+CGCONTRDP: 1,5,vzwims,38.0.16.18.17.92.67.44.93.225.77.204.158.49.92.66, 254.128.0.0.0.0.0.0.0.0.0.0.0.0.0.1, 32.1.72.136.0.101.255.0.6.46.0.13.0.0.0.0, 32.1.72.136.0.100.255.0.6.32.0.13.0.0.0.0,32.1.72.136.0.5.113.58.0.224.1.4.0.0.1.29,32.1.72.136.0.5.113.58.0.224.1.4.0.0.0.117
##Note: this is a Verizon modem , (PDN1) VZWIMS is the default attach profile, but data is on PDN3
at+cgpiaf=1
at+cgcontrdp
+CGCONTRDP: 1,5,vzwims,2600:1012:115C:432C:5DE1:4DCC:9E31:5C42, FE80:0:0:0:0:0:0:1, 2001:4888:65:FF00:62E:D:0:0, 2001:4888:64:FF00:620:D:0:0,2001:4888:5:713A:E0:104:0:11D,2001:4888:5:713A:E0:104:0:75
at!scact=1
at+cgcontrdp
+CGCONTRDP: 3,6,VZWINTERNET,100.114.158.6,2600:1012:B143:2AF0:0:36:4E86:A01,0.255.101.0 FE80:0:0:0:0:36:4E86:A40,198.224.171.135 2001:4888:65:FF00:62E:D:0:0,198.224.169.135 2001:4888:64:FF00:620:D:0:0
##close the AT port
On Linux shell:
#dhclient enp0s20u6i8
#ifconfig enp0s20u6i8
enp0s20u6i8 Link encap:Ethernet HWaddr 3e:bd:20:44:e5:cc
inet addr:100.114.158.6 Bcast:100.114.158.7 Mask:255.255.255.252
inet6 addr: fe80::3cbd:20ff:fe44:e5cc/64 Scope:Link
inet6 addr: 2600:1012:b143:2af0:3cbd:20ff:fe44:e5cc/64 Scope:Global
inet6 addr: 2600:1012:b143:2af0:908:dc70:a4f0:7af9/64 Scope:Global
UP BROADCAST RUNNING NOARP MULTICAST MTU:1428 Metric:1
RX packets:3 errors:0 dropped:0 overruns:0 frame:0
TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:776 (776.0 B) TX bytes:712 (712.0 B)
route add 8.8.8.8 enp0s20u6i8
ping -c2 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=118 time=221 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=118 time=36.1 ms
— 8.8.8.8 ping statistics —
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 36.135/128.695/221.255/92.560 ms
#of course I’m only adding 8.8.8.8 to the route.
#you may need to add your own routes
#for name resolution /etc/resolv.conf must be populated with a nameserver
