Instruction to install GOBI net and serial
#1
Can anyone send me an instruction to install GOBI net and serial for MC7455?
Thank you in advance,
Tony,
#2
Tony,
#3
Tony,
As I have just replied in your other post (link below), the process to install in a standard system is in the document attach to that post, cross compiling is more involved and I suggest you get some generic instructions for your platform for this.
#4
Hi Matt,
It happens to me that I can’t open the text files embedded within the word document.
Can you send me the link to all the text files?
Thank you,
Tony,
#5
Tony,
I specifically gave it as a word document so that you could access then so not sure why you cannot, anyway here they are attached to this post.
Building drivers.txt (10.2 KB)
ttyUSB2 to run 3G and AT commands at the same time
#6
Thank you Matt, I’ll try your instruction to see if it works.
#7
my error log:
root@KN2018:~# cd /GobiSerial
root@KN2018:/GobiSerial# make
rm -rf *.o ~ core .depend ..cmd *.ko .mod.c .tmp_versions Module. modules.order
make -C /lib/modules/4.14.51/build M=/GobiSerial modules
make[1]: Entering directory ‘/lib/modules/4.14.51/build’
make[1]: *** No rule to make target ‘modules’. Stop.
make[1]: Leaving directory ‘/lib/modules/4.14.51/build’
make: *** [Makefile:16: all] Error 2
#8
Hi Matt,
Please help me out,
Thank you,
Tony
#9
I installed Gobiserial in my PC and it working on kernel level but i can’t see ttyUSB3 in my pc.
how can i see ttyUSB3?
PFA dmesg log.
[ 234.410883] usb 2-1: Qualcomm USB modem converter now attached to ttyUSB1
[ 234.411373] qcserial 2-1:1.3: Qualcomm USB modem converter detected
[ 234.411893] usb 2-1: Qualcomm USB modem converter now attached to ttyUSB2
[ 234.412393] GobiNet: loading out-of-tree module taints kernel.
[ 234.412490] GobiNet: module verification failed: signature and/or required key missing - tainting kernel
[ 234.417896] usbcore: registered new interface driver cdc_wdm
[ 234.418984] GobiNet: 2017-02-28/SWI_2.41
[ 234.420055] GobiNet 2-1:1.8 eth0: register ‘GobiNet’ at usb-0000:00:14.0-1, GobiNet Ethernet Device, 5e:27:b4:4a:21:19
[ 234.421604] USB Speed : USB 2.0
[ 234.421669] usbcore: registered new interface driver GobiNet
[ 234.428923] usbcore: registered new interface driver GobiSerial
[ 234.428967] usbserial: USB Serial support registered for GobiSerial
[ 234.429001] GobiSerial: 2017-01-04/SWI_2.27:GobiSerial
[ 234.439708] usbcore: registered new interface driver qmi_wwan
[ 234.443269] cdc_ether 2-1:1.19 enp0s20u1i19: renamed from usb0
[ 234.473762] GobiNet 2-1:1.8 enp0s20u1i8: renamed from eth0
[ 234.524325] IPv6: ADDRCONF(NETDEV_UP): enp0s20u1i19: link is not ready
[ 234.524520] cdc_ether 2-1:1.19 enp0s20u1i19: kevent 12 may have been dropped
[ 234.524530] cdc_ether 2-1:1.19 enp0s20u1i19: kevent 12 may have been dropped
[ 234.627005] cdc_ether 2-1:1.19 enp0s20u1i19: kevent 12 may have been dropped
