you can try the exe of 5.5.26.0
How to install this file GL8200_asm.stp?
Where does this file come from?
Same the version you have mentioned.
i don’t see file GL8200_asm.stp
You can see here on how to upgrade through XMODEM:
i have downloaded RHL85xx.5.5.26.0.201912270948.x6250_5_exe file and this is giving below output
Log file is “C:\Users\AM0036~1\AppData\Local\Temp\HL8FW_r6930.log”
Use Port: USB1
Intel Command Line FlashTool v.1.37 1.3-r33 (Download Library v.4.140,0.0 )
psi.fls (PSI) (NAND)
slb.fls (SLB) (NAND)
AENEAS_FW.fls (Code) (NAND)
SAM_6260.fls (Code) (NAND)
SAM_6260-MSY.fls (Code) (NAND)
SAM_6260-CDS.fls (Code) (NAND)
Booting ‘C:\Users\AM0036~1\AppData\Local\Temp\7zS60A6.tmp\temp\psi.fls’, memclass: PSI
→ Please reboot your phone device ←
Process time was 1 min 0 sec.
Library Error: IMCDownload.cpp:508 - USB Boot Timeout (1)
Please refer to the log file “C:\Users\AM0036~1\AppData\Local\Temp\HL8FW_r6930.log”
Press any key to continue . . .
we have mailed to reseller and the have reverted.
In reference to your email, we have checked with our internal team for the same, please be informed that the error of 513 is network related error for part 1645-GL8200_1104500-ND on the sales order 75973996.
Since the error of 513 is a network related error, it has nothing to do with the modem, Hence the product is not damaged.
Hence, we request you to please check your network coverage area.
maybe there is no more 3G network coverage in your area
i have used another simcard and it is registered still no sms going
+CMS error : 302
what could be the issue
What is at+creg? Now
Can this SIM card send SMS in a phone?
ERROR 302 means operation is not allowed for SMS.
Yes we are able to send the sms using this sim from mobile
What is at+creg? And ati3 now
Are you able to send SMS in PDU format with AT+CGMF=0?
