Hi, I am using the BX3105 Module (BX310x.2.7.3 Firmware) as Bluetooth SPP Client, so I configured the module as following:
AT+SRBTSYSTEM=2\r
AT+SRBTNAME=TEST\r
AT+SRBTSTATE=1,2\r
AT+SRBTCPROFILES=1\r
Then I connect my Smartphone with the Module, everthing works fine, I can send and receive over SPP.
I want to get the RSSI Value of the connected Smartphone, so I write:
AT+SRBTCRSSI=1\r
and get
+SRBTCRSSI: 1,0\r\n
OK\r\n
back.
Referd to the AT Command Reference it should be:
+SRBTCRSSI: rssi-value\r\n
OK\r\n
Did I miss something?
Best regards,
Mathias Brandl
Hi @mathias.brandl,
I have just tried on my BX310x module loading offical FW 2.7.3, I also see this issue.
You can refer this log:
ati3
BX310x.2.7.3
at+srbtsystem=2
at+srbtname=test
at+srbtstate=1,2
at+srbtcprofiles=1
at+Srbtaddr?
+SRBTADDR: "20:fa:bb:20:0a:fe"
+SRBTPAIR: "20:fa:bb:01:90:8c",1
+SRBTCFG: 1,0,"20:fa:bb:01:90:8c",SPP,0
+SRSPPCNX: 1,1,129
+SRSPP_DATA: 1,5,hello
AT+SRBTCRSSI=1
+SRBTCRSSI: 1,-2
AT+SRBTCRSSI=1
+SRBTCRSSI: 1,-2
It seems that having a document issue at here, maybe it should be +SRBTCRSSI: <session ID>,<rssi-value>. However, I think it’s better that you should contact your distributor to ask about this difference. You can use my log to provide more information for your issue.
