Currently RSSI level send in BIM by the modem is 23 as inthe following when no attenuation is applied:
2023-09-18_13:35:38.87689 >>>>>> service = ‘basic-connect’ (a289cc33-bcbb-8b4f-b6b0-133ec2aae6df)
2023-09-18_13:35:38.87690 >>>>>> cid = ‘signal-state’ (0x0000000b)
2023-09-18_13:35:38.87691 >>>>>> Fields:
2023-09-18_13:35:38.87691 >>>>>> Rssi = ‘23’
2023-09-18_13:35:38.87694 >>>>>> ErrorRate = ‘99’
2023-09-18_13:35:38.87695 >>>>>> SignalStrengthInterval = ‘5’
2023-09-18_13:35:38.87696 >>>>>> RssiThreshold = ‘2’
2023-09-18_13:35:38.87696 >>>>>> ErrorRateThreshold = ‘4294967295’
2023-09-18_13:35:38.87697 >>>>>> RsrpSnr = ‘{
2023-09-18_13:35:38.87698 >>>>>> }’
the AT+CSQ command gives 31 which is not consistent.
Consequently Signal Strength calculation is 70% instead of 100%.
Thanks for your support
jyijyi
September 20, 2023, 3:45pm
2
what is the return of AT!GSTATUS?
what FW are you using?
I don’t have the result of AT!GSTATUS? but we are directly connected to a simulator by cabling.
The software use is SWIX55C_03.09.06.00-001_GENERIC_030.038_000
jyijyi
September 20, 2023, 4:01pm
4
you can double check with the value in AT!GSTATUS? and see if it matches with your setup
Here is GSTATUS response which seems coherent with our set-up:
Current Time: 72954 Temperature: 43
Thermal Mitigation Level: 0
Reset Counter: 1 Mode: ONLINE
LTE band: B1 LTE bw: 10 MHz
LTE Rx chan: 300 LTE Tx chan: 18300
RRC state: RRC Connected
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: NO SMS,UNKNOWN VoIP
PCC RxM RSSI: -49 PCC RxM RSRP: -73
PCC RxD RSSI: — PCC RxD RSRP: —
PCC RxM1 RSSI: — PCC RxM1 RSRP: —
PCC RxD1 RSSI: — PCC RxD1 RSRP: —
PCC Tx Power: -41 TAC: 0001 (1)
RSRQ (dB): -6.5 Cell ID: 01a2d001 (27447297)
SINR (dB): 29.8
NR5G band: — NR5G bw: —
NR5G Tx Power: — NR5G Tx chan: —
NR5G Rx chan: — NR5G RSRP (dBm): —
NR5G RSRQ (dB): — NR5G SINR (dB): —
jyijyi
September 21, 2023, 10:34am
6
Ok, then you can use this command instead of at+csq
We are using the spontaneous message as explained above, at+csq is correct, GSTATUS is correct, but not the sponatenous one.
Do you confirm there is an issue with this message ? If, yes what is the next step.
jyijyi
September 21, 2023, 2:24pm
8
I don’t know how you get this spontaneous message …
By QMI?
By mbimcli command?
By MBPL SDK API?
By mbim, it is the NDIS_WWAN_SIGNAL_STATE.
jyijyi
September 21, 2023, 3:09pm
10
mbimcli is a 3rd party application, not developed by Sierra
Not quite sure how to convert this “RSSI+ Signal strength interval + RSSI threshold” into dbm unit as stated in AT!GSTATUS.
why can’t you use AT command instead?
Have you tried the MBPL SDK?
This value is supposed to be between 0 and 31. It should be 31 in this case.
The mbim is a third party but the porting is serria scope i supposed.
We will need to workaound and it will be great that you fix this issue in a future release.
jyijyi
September 25, 2023, 12:08pm
12
Have you contacted distributor on this?
I don’t think this is in the scope of SWI module
I tested on LTE module EM7565, it has same deviation:
owner@ubuntu:~$ sudo mbimcli -d /dev/cdc-wdm0 --query-signal-state
[/dev/cdc-wdm0] Signal state:
RSSI [0-31,99]: '10'
Error rate [0-7,99]: '99'
Signal strength interval: '5'
RSSI threshold: '2'
Error rate threshold: 'unspecified'
at+Csq
+Csq: 25,99
at!gstatus?
!GSTATUS:
Current Time: 64 Temperature: 34
Reset Counter: 2 Mode: ONLINE
LTE band: B1 LTE bw: 15 MHz
LTE Rx chan: 374 LTE Tx chan: 18374
LTE SCC1 state:NOT ASSIGNED
LTE SCC2 state:NOT ASSIGNED
LTE SCC3 state:NOT ASSIGNED
LTE SCC4 state:NOT ASSIGNED
RRC state: RRC Idle
IMS reg state: No Srv IMS mode: Normal
PCC RxM RSSI: -61 PCC RxM RSRP: -91
PCC RxD RSSI: -92 PCC RxD RSRP: -131
Tx Power: -- TAC: 2775 (10101)
RSRQ (dB): -11.8 Cell ID: 00360a20 (3541536)
SINR (dB): 3.0
ati3
Model: EM7565
Revision: SWI9X50C_01.14.05.00 f546ac jenkins 2020/12/01 03:20:39
IMEI: 353533103912345
IMEI SV: 13
FSN: UF221731112345
+GCAP: +CGSM
