FX30S Factory Reset
When I trying to configure a new modem FX30S with Hyperterminal (AT Commands), I lost the modem, I think after sending the command: AT! MAPUART = 15.1
So now I try to reset to factory default setting the modem, but i can’t! I see in the manual that it is necessary to enable the factory default by using this command: AT!FWD=FACTORYRECOVERY, ENABLE
What must I do now?
Didn’t you have the AT command port in usb
Yes I have usb port.
Now AT Commands works with usb port.
I have to change serial port rate to 9600, which commands I have to use: ‘AT+IPR=9600’?
How can I see the serial port rate? ‘AT+IPR=?’ don’t works.
You can try at+ipr? In the serial port
Don’t works! response is OK but I don’t see the rate.
What is the return of at!mapuart?
at!mapuart Return ERROR
I used USB port when I sent this command. must I use serial port?
because serial port don’t works even after reset factory setting!
Did you add question mark
Yes! I Added question mark
I don’t see problem in my WP76 module to enter AT!MAPUART command in USB AT port:
at!mapuart?
!MAPUART: 17,16
ati3
Model: WP7605
Revision: SWI9X07Y_02.28.03.05 000000 jenkins 2019/07/08 11:04:16
IMEI: 353532100020465
IMEI SV: 6
FSN: 2A917285070404
+GCAP: +CGSM
It looks like i made a mistake, so here is what i get:
AT!MAPUART?
!MAPUART: 15,0
ATI3
Model: FX30S(WP7702)
Revision: SWI9X06Y_02.16.06.00 7605a6 jenkins 2018/06/20 17:56:12
IMEI: 354723090173138
IMEI SV: 2
FSN: VU030386390110
+GCAP: +CGSM
your uart1 has been set to 15 which is not useful…
What is the good URT1 setting?
How about setting it to AT command mode?
Ok fine! now going back to my original question: how can I see rate setting and change it?
I tried: at+ipr? and at+ipr =? both commands return OK
at!mapuart?
!MAPUART: 1,0
at+ipr?
at+ipr=?
Are you typing this in usb AT port?
Yes, I try it, I have the same thing!
you mean both UART and USB will return the same on AT+IPR?
