[Fx30] MTDBLOCK5 usage
I am using the MTDBLOCK5 (/mnt/userrw) to store elements which need to survive a factory reset.
This partition is only 5MB big, so I’m quickly reaching its limit.
I have 2 questions for you:
  • What are the Sierrawireless files stored in this partition for? Can I remove them?
  • The block size of this partition is 4KB, could you give hints to change this block size to 2KB to store more efficiently small files?
Thanks, Christian.
Hi @rkirk,
Would you be able to help Christian with his questions please?
Chris
Could you answer … at least the first question?
Thanks, Christian.
Hello Christian,
The userrw partition contains the power management controller binary, configuration information and configuration backups.
I would recommend not removing any of these files to ensure your device functions properly.
BR,
Chris
