FX30 + IoT CAN Bus Card
I have FX30 GENERIC,3G which sends data to IoT platform (simulated data). Now I would like to connect with CAN bus and collect real data from other devices in CAN network.
With the IoT CAN card, it looks like I can connect to CAN network. However this IoT CAN device is not supported in the standard firmware of FX30. I need to rebuild the firmware to include the support.
I have downloaded the latest source:
http://downloads.sierrawireless.com/airlink/FX30/FX30_WP8548_full_R14.0.4.002.tar.gz
After extracting, when I run ‘make image_bin’ the following error is reported:
ERROR: Function failed: do_compile (log file is located at
/legato/yocto/build_bin/tmp/work/x86_64-linux/automake-native/1.14.1-r0/temp/log.do_compile.7095)
ERROR: Logfile of failure stored in: /legato/yocto/build_bin/tmp/work/x86_64-linux/automake-native/1.14.1-r0/temp/log.do_compile.7095
help2man: can’t get --help' info from automake-1.14 | Try –no-discard-stderr’ if option outputs to stderr
| Makefile:3707: recipe for target ‘doc/automake-1.14.1’ failed
| make: *** [doc/automake-1.14.1] Error 255
| ERROR: oe_runmake failed
| exit 1
Any idea how to solve this?
RP
Hi RP,
Is this issue related to your other posting? If so, can you please try building using Ubuntu 16.04 instead?
BR,
Chris
Thanks Chris. With Ubuntu 16.04, I could build it.
