FX30 availability, support, roadmap
It appears the FX30 will satisfy requirements for several projects. However, it appears that FX30 may no longer be available. Distributors and Digikey indicate Unavailable. Contacting Sierra referred back to the distributor.
Can you share the current state of FX30 production and availability?
Can you provide information regarding the roadmap for FX30? It is aging and some assurances are needed regarding future availability and support. Also, can you share any plans for a successor product?
These details are essential determiners for selection of Sierra and Octave going forward.
Thank you.
Any input available from Sierra?
After a few months of supply constraints, and some additional multi-sourcing qualifications, FX30 deliveries started again at the end of May 2022, and will continue to grow in the next months. There is no plan to discontinue the product. Please ask our Distributors when they can supply: https://www.sierrawireless.com/octave/partnerships/
On a related note, the models that are available use a different Part Number than is listed in the datasheet (ex. “1103214” on Digikey). It is unclear whether a given part is NA, EMEA, or Global. Is there a table of these part numbers somewhere to get this information and choose the correct model from what is in stock?
Hi @kmuster ,
Welcome you to our community!
For details on the operating area of each FX30 type, you can refer to the documents below:
SierraWireless_FX30Series_Datasheet.pdf (126.6 KB)
For the part number of each FX30, please contact your nearest Sierra distributor to obtain it.
