Have an FX30 that has been only on AT&T, never has been on Verizon. Running AT&T firmware.
I was having trouble connecting, LED would flash green then red, alterating.
Went to connect tonight and the APN is showing Verizon. I never set the APN to Verizon, not one time.
Checked the AT commands, sure enough something internally has set it to Verizon.
AT+CGDCONT?
+CGDCONT: 1,“IP”,“VZWINTERNET”,“0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 4,“IPV4V6”,“attm2mglobal”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
I am supposed to be dropping a test unit with a customer tomorrow and this cannot happen in the field.
Anyone know what is going on?
This unit has been running fine on AT&T for 2 weeks now.
Rebooted the unit again…
Index: 1
APN: VZWINTERNET
PDP Type: IPV4
Connected: no
It appears that the unit is alternating between AT&T and Verizon everytime I check the status…
AT+CGDCONT?
+CGDCONT: 1,"IP","VZWINTERNET","0.0.0.0",0,0,0,0
+CGDCONT: 2,"IPV4V6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
+CGDCONT: 3,"IPV4V6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
+CGDCONT: 4,"IPV4V6","attm2mglobal","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
AT+CGDCONT?
+CGDCONT: 1,"IP","nmrx11.com.attz","0.0.0.0",0,0,0,0
AT+CGDCONT?
AT+CGDCONT?
This is alternating between the two with me only issuing the command, AT+CGDCONT?
Then through SSH…
root@fx30s:~# cm data
Index: 1
APN: VZWINTERNET
PDP Type: IPV4
Connected: no
Index: 1
APN: VZWINTERNET
PDP Type: IPV4
Connected: no
Index: 1
APN: nmrx11.com.attz
PDP Type: IPV4
Connected: no
Index: 1
APN: VZWINTERNET
PDP Type: IPV4
Connected: no
Index: 1
PDP Type: IPV4
Connected: no
Index: 1
PDP Type: IPV4
Connected: no
Unit is fighting with itself or something. These ‘cm data’ commands are issued back to back to back.
