Which cert are you going to do
Have you tried the generic one
We are simply trying to demonstrate our abilities as a lab to perform FR2 testing. So any firmware that supports FR2 would work. Do you recommend the Generic FW? Also, is there software we can download to easily upgrade the module from one FW to another?
Thanks!
for the tool to upgrade FW, you can see release note
Hi
we flashed our board 9190 with SWIX55C_03.09.11.00-001_GENERIC_030.044_001 but it is supporting only sub 6GHZ . is there any firmware which supports mm wave .
thank you
what is the AT command return for your EM9190 module?
ati3
AT!impref?
AT!entercnd=“A710”
at!band?
at!band=?
at!selrat?
at!sdpref?
Here is the setting for EM9191 which only supports sub6:
at!entercnd="A710"
at!band=?
Index, Name
00, All bands
0 - GW: 100600000FC00000
1 - LTE: 0000A7E2BB0F38DF 0000000000000042
3 - NRNSA: 000081A0090808D7 0000000000007042
4 - NRSA: 000081A0090808D7 0000000000007042
01, Europe 3G
0 - GW: 0002000000400000
1 - LTE: 0000000000000000 0000000000000000
3 - NRNSA: 0000000000000000 0000000000000000
4 - NRSA: 0000000000000000 0000000000000000
02, North America 3G
0 - GW: 0000000004800000
06, Europe
1 - LTE: 00000000000800C5 0000000000000000
07, North America
1 - LTE: 000001000301385A 0000000000000042
08, WCDMA ALL
09, LTE ALL
0 - GW: 0000000000000000
0C, NR5G ALL
Available:
0 - GW:
1000000000000000 - B19 (850)
0004000000000000 - B9 (1700)
0002000000000000 - B8 (900)
0000000008000000 - B6 (800)
0000000004000000 - B5 (850)
0000000002000000 - B4 (1700)
0000000001000000 - B3 (1700)
0000000000800000 - B2 (1900)
0000000000400000 - B1 (2100)
1 - LTE:
1/0000800000000000 - B48
1/0000200000000000 - B46
1/0000040000000000 - B43
1/0000020000000000 - B42
1/0000010000000000 - B41
1/0000008000000000 - B40
1/0000004000000000 - B39
1/0000002000000000 - B38
1/0000000200000000 - B34
1/0000000080000000 - B32
1/0000000020000000 - B30
1/0000000010000000 - B29
1/0000000008000000 - B28
1/0000000002000000 - B26
1/0000000001000000 - B25
1/0000000000080000 - B20
1/0000000000040000 - B19
1/0000000000020000 - B18
1/0000000000010000 - B17
1/0000000000002000 - B14
1/0000000000001000 - B13
1/0000000000000800 - B12
1/0000000000000080 - B8
1/0000000000000040 - B7
1/0000000000000010 - B5
1/0000000000000008 - B4
1/0000000000000004 - B3
1/0000000000000002 - B2
1/0000000000000001 - B1
2/0000000000000040 - B71
2/0000000000000002 - B66
3 - NRNSA:
1/0000800000000000 - n48
1/0000010000000000 - n41
1/0000008000000000 - n40
1/0000002000000000 - n38
1/0000000008000000 - n28
1/0000000001000000 - n25
1/0000000000080000 - n20
1/0000000000000800 - n12
1/0000000000000080 - n8
1/0000000000000040 - n7
1/0000000000000010 - n5
1/0000000000000004 - n3
1/0000000000000002 - n2
1/0000000000000001 - n1
2/0000000000004000 - n79
2/0000000000002000 - n78
2/0000000000001000 - n77
2/0000000000000040 - n71
2/0000000000000002 - n66
4 - NRSA:
at!band?
Index, Name
00, All bands,
at!sdpref?
RATs : WCDMA,LTE,NR5G
GWC : B1,B2,B4,B5,B6,B8,B9,B19
LTE : B1,B2,B3,B4,B5,B7,B8,B12,B13,B14,B17,B18,B19,B20,B25,B26,B28,B29,B30,B32,B34,B38,B39,B40,B41,B42,B43,B46,B48,B66,B71
TDS :
NRSA : n1,n2,n3,n5,n7,n8,n12,n20,n25,n28,n38,n40,n41,n48,n66,n71,n77,n78,n79
NRNSA: n1,n2,n3,n5,n7,n8,n12,n20,n25,n28,n38,n40,n41,n48,n66,n71,n77,n78,n79
Hi jyijyi,
Find the device response for AT commands
Sent “ati3”
[13:14:23]: Received ati3 from Device Under Test
[13:14:23]: Received Manufacturer: Sierra Wireless, Incorporated from Device Under Test
[13:14:23]: Received Model: EM9190 from Device Under Test
[13:14:23]: Received Revision: SWIX55C_03.09.11.00 7bf975 jenkins 2022/06/10 20:36:01 from Device Under Test
[13:14:23]: Received IMEI: 351735110128382 from Device Under Test
[13:14:23]: Received IMEI SV: 22 from Device Under Test
[13:14:23]: Received FSN: 4H1203020501A1 from Device Under Test
[13:14:23]: Received +GCAP: +CGSM from Device Under Test
[13:14:23]: Received OK from Device Under Test
[13:15:36]: Sending ‘at!impref?’ to ‘Device Under Test’
[13:15:36]: Sent “at!impref?”
[13:15:36]: Received at!impref? from Device Under Test
[13:15:36]: Received !IMPREF: from Device Under Test
[13:15:36]: Received preferred fw version: 03.09.11.00 from Device Under Test
[13:15:36]: Received preferred carrier name: GENERIC from Device Under Test
[13:15:36]: Received preferred config name: GENERIC_030.044_001 from Device Under Test
[13:15:36]: Received preferred subpri index: 000 from Device Under Test
[13:15:36]: Received current fw version: 03.09.11.00 from Device Under Test
[13:15:36]: Received current carrier name: GENERIC from Device Under Test
[13:15:36]: Received current config name: GENERIC_030.044_001 from Device Under Test
[13:15:36]: Received current subpri index: 000 from Device Under Test
[13:15:36]: Received OK from Device Under Test
[13:16:24]: Sending ‘AT!entercnd=“A710”’ to ‘Device Under Test’
[13:16:24]: Sent "AT!entercnd=“A710"”
[13:16:24]: Received AT!entercnd=“A710” from Device Under Test
[13:16:24]: Received OK from Device Under Test
[13:16:45]: Sending ‘AT!band?’ to ‘Device Under Test’
[13:16:45]: Sent “AT!band?”
[13:16:45]: Received AT!band? from Device Under Test
[13:16:45]: Received Index, Name from Device Under Test
[13:16:45]: Received 00, All bands, from Device Under Test
[13:16:45]: Received 0 - GW: 100600000FC00000 from Device Under Test
[13:16:45]: Received 1 - LTE: 0000A3E2BB0F38DF 0000000000000042 from Device Under Test
[13:16:45]: Received 3 - NRNSA: 0000010008000017 0000000000007042 from Device Under Test
[13:16:45]: Received 4 - NRSA: 0000010008000017 0000000000007042 from Device Under Test
[13:16:45]: Received OK from Device Under Test
[13:16:52]: Sending ‘AT!band=?’ to ‘Device Under Test’
[13:16:52]: Sent “AT!band=?”
[13:16:52]: Received AT!band=? from Device Under Test
[13:16:52]: Received Index, Name from Device Under Test
[13:16:52]: Received 00, All bands from Device Under Test
[13:16:52]: Received 0 - GW: 100600000FC00000 from Device Under Test
[13:16:52]: Received 1 - LTE: 0000A3E2BB0F38DF 0000000000000042 from Device Under Test
[13:16:52]: Received 3 - NRNSA: 0000010008000017 0000000000007042 from Device Under Test
[13:16:52]: Received 4 - NRSA: 0000010008000017 0000000000007042 from Device Under Test
[13:16:52]: Received 01, Europe 3G from Device Under Test
[13:16:52]: Received 0 - GW: 0002000000400000 from Device Under Test
[13:16:52]: Received 1 - LTE: 0000000000000000 0000000000000000 from Device Under Test
[13:16:52]: Received 3 - NRNSA: 0000000000000000 0000000000000000 from Device Under Test
[13:16:52]: Received 4 - NRSA: 0000000000000000 0000000000000000 from Device Under Test
[13:16:52]: Received 02, North America 3G from Device Under Test
[13:16:52]: Received 0 - GW: 0000000004800000 from Device Under Test
[13:16:52]: Received 06, Europe from Device Under Test
[13:16:52]: Received 1 - LTE: 00000000000800C5 0000000000000000 from Device Under Test
[13:16:52]: Received 07, North America from Device Under Test
[13:16:52]: Received 1 - LTE: 000001000301385A 0000000000000042 from Device Under Test
[13:16:52]: Received 08, WCDMA ALL from Device Under Test
[13:16:52]: Received 09, LTE ALL from Device Under Test
[13:16:52]: Received 0 - GW: 0000000000000000 from Device Under Test
[13:16:52]: Received 0C, NR5G ALL from Device Under Test
[13:16:52]: Received Available: from Device Under Test
[13:16:52]: Received 0 - GW: from Device Under Test
[13:16:52]: Received 1000000000000000 - B19 (850) from Device Under Test
[13:16:52]: Received 0004000000000000 - B9 (1700) from Device Under Test
[13:16:52]: Received 0002000000000000 - B8 (900) from Device Under Test
[13:16:52]: Received 0000000008000000 - B6 (800) from Device Under Test
[13:16:52]: Received 0000000004000000 - B5 (850) from Device Under Test
[13:16:52]: Received 0000000002000000 - B4 (1700) from Device Under Test
[13:16:52]: Received 0000000001000000 - B3 (1700) from Device Under Test
[13:16:52]: Received 0000000000800000 - B2 (1900) from Device Under Test
[13:16:52]: Received 0000000000400000 - B1 (2100) from Device Under Test
[13:16:52]: Received 1 - LTE: from Device Under Test
[13:16:52]: Received 1/0000800000000000 - B48 from Device Under Test
[13:16:52]: Received 1/0000200000000000 - B46 from Device Under Test
[13:16:52]: Received 1/0000020000000000 - B42 from Device Under Test
[13:16:52]: Received 1/0000010000000000 - B41 from Device Under Test
[13:16:52]: Received 1/0000008000000000 - B40 from Device Under Test
[13:16:52]: Received 1/0000004000000000 - B39 from Device Under Test
[13:16:52]: Received 1/0000002000000000 - B38 from Device Under Test
[13:16:52]: Received 1/0000000200000000 - B34 from Device Under Test
[13:16:52]: Received 1/0000000080000000 - B32 from Device Under Test
[13:16:52]: Received 1/0000000020000000 - B30 from Device Under Test
[13:16:52]: Received 1/0000000010000000 - B29 from Device Under Test
[13:16:52]: Received 1/0000000008000000 - B28 from Device Under Test
[13:16:52]: Received 1/0000000002000000 - B26 from Device Under Test
[13:16:52]: Received 1/0000000001000000 - B25 from Device Under Test
[13:16:52]: Received 1/0000000000080000 - B20 from Device Under Test
[13:16:52]: Received 1/0000000000040000 - B19 from Device Under Test
[13:16:52]: Received 1/0000000000020000 - B18 from Device Under Test
[13:16:52]: Received 1/0000000000010000 - B17 from Device Under Test
[13:16:52]: Received 1/0000000000002000 - B14 from Device Under Test
[13:16:52]: Received 1/0000000000001000 - B13 from Device Under Test
[13:16:52]: Received 1/0000000000000800 - B12 from Device Under Test
[13:16:52]: Received 1/0000000000000080 - B8 from Device Under Test
[13:16:52]: Received 1/0000000000000040 - B7 from Device Under Test
[13:16:52]: Received 1/0000000000000010 - B5 from Device Under Test
[13:16:52]: Received 1/0000000000000008 - B4 from Device Under Test
[13:16:52]: Received 1/0000000000000004 - B3 from Device Under Test
[13:16:52]: Received 1/0000000000000002 - B2 from Device Under Test
[13:16:52]: Received 1/0000000000000001 - B1 from Device Under Test
[13:16:52]: Received 2/0000000000000040 - B71 from Device Under Test
[13:16:52]: Received 2/0000000000000002 - B66 from Device Under Test
[13:16:52]: Received 3 - NRNSA: from Device Under Test
[13:16:52]: Received 1/0000010000000000 - n41 from Device Under Test
[13:16:52]: Received 1/0000000008000000 - n28 from Device Under Test
[13:16:52]: Received 1/0000000000000010 - n5 from Device Under Test
[13:16:52]: Received 1/0000000000000004 - n3 from Device Under Test
[13:16:52]: Received 1/0000000000000002 - n2 from Device Under Test
[13:16:52]: Received 1/0000000000000001 - n1 from Device Under Test
[13:16:52]: Received 2/0000000000004000 - n79 from Device Under Test
[13:16:52]: Received 2/0000000000002000 - n78 from Device Under Test
[13:16:52]: Received 2/0000000000001000 - n77 from Device Under Test
[13:16:52]: Received 2/0000000000000040 - n71 from Device Under Test
[13:16:52]: Received 2/0000000000000002 - n66 from Device Under Test
[13:16:52]: Received 4 - NRSA: from Device Under Test
[13:16:52]: Received OK from Device Under Test
[13:17:10]: Sending ‘AT!SELRAT?’ to ‘Device Under Test’
[13:17:10]: Sent “AT!SELRAT?”
[13:17:10]: Received AT!SELRAT? from Device Under Test
[13:17:10]: Received !SELRAT: 00, Automatic from Device Under Test
[13:17:10]: Received OK from Device Under Test
[13:17:29]: Sending ‘AT!sdpref?’ to ‘Device Under Test’
[13:17:29]: Sent “AT!sdpref?”
[13:17:29]: Received AT!sdpref? from Device Under Test
[13:17:29]: Received RATs : WCDMA,LTE,NR5G from Device Under Test
[13:17:29]: Received GWC : B1,B2,B4,B5,B6,B8,B9,B19 from Device Under Test
[13:17:29]: Received LTE : B1,B2,B3,B4,B5,B7,B8,B12,B13,B14,B17,B18,B19,B20,B25,B26,B28,B29,B30,B32,B34,B38,B39,B40,B41,B42,B46,B48,B66,B71 from Device Under Test
[13:17:29]: Received TDS : from Device Under Test
[13:17:29]: Received NRSA : n1,n2,n3,n5,n28,n41,n66,n71,n77,n78,n79 from Device Under Test
[13:17:29]: Received NRNSA: n1,n2,n3,n5,n28,n41,n66,n71,n77,n78,n79 from Device Under Test
[13:17:29]: Received OK from Device Under Test
We want device supporting mm wave bands supporting:n257 ,n258,n260,n261 any firmware available?
Thank you
you need to contact distributor to have mmwave band
okay Thank you so much
