FCM on GPRS Flow
hello,
first sorry for my bad english.
I’m new at OpenAT and I spend few weeks reading documentations and trying some sample Applications.
I’m using an Evaluationboard with a Wireless CPU Q2687 with 663 Verion of Firmware.
The OS-Version is 4.21
I’m also using the Wip-Plugin Verion 3.10.2030
I’m writting my programcode in Ecipse with an gcc Compiler, as it comes as standard IDE with the SDK.
My aim is to establish a GPRS Connection and to subscribe to FCM on GPRS, so that I can receive incoming data to check them.
If there is coming some special data, other functions should be executed.
But at first I’ve got a problem with the FCM-Service and GPRS.
I trying to establish an GPRS Connection.
This works I think, but when I subscribe to the FCM with GPRS as Port I get some strange behavior.
And there is something else I’m bit confused about.
In the Target Monitoring Tool I get some Traces all beginning with “[GPRS]” which I’ve not written in my Code.
Are this standard Traces from the OS?
When I subscribe to the FCM-Service using GPRS Port, I’ve got the "FLOW OPENED’ - Event from my FCM-Control-Handler
but immediately after this I’ve got the “FLOW CLOSED”-Event.
Thereafter the GPRS Connection is closed, without any reason as far as I can see.
This is the way I tried:
-> First I’m subscribing to the SIM-Service
->when I get the event “ADL_SIM_EVENT_FULL_INIT” I subscribe to the GPRS-Service using the function ‘adl_gprsSubscribe’
then I’m sending the AT-Command “AT+CGATT=1” using ‘atCmdCreate’, because I want to attach to the GPRS-Network.
(I’m unable to find an equal function for this, so I can’t avoid using ‘CmdCreate’).
-> then when I receive the Event “ADL_GPRS_EVENT_ME_ATTACH” I’m starting an IP-Bearer using wip-function ‘wip_bearerOpen’.
then I set the Options for GPRS like APN and so on.
and at the end I start the Bearer with the command ‘wipbearerStart’
-> on the Event “ADL_GPRS_EVENT_ACTIVATE_OK” from my GPRS-Eventhandler I’m subscribing to the FCM on GPRS Port
-> when I get the “Event WIP_BEV_IP_CONNECTED” from my GPRS-Bearer-Handler I created an TCP-Client Socket using ‘wip_TCPClientCreate’
-> At last I get the “WIP_CEV_OPEN” Event
#include "adl_global.h"
#include "wip_bearer.h"
#include "wip.h"
/*  Mandatory variables                                                    */
/*  wm_apmCustomStackSize                                                  */
const u16 wm_apmCustomStackSize = 1024;
/*  Local variables                                                        */
static wip_bearer_t myBearer;
static wip_channel_t TcpSocket;
/*  Prototypes        */
static void myHandler (wip_bearer_t *br, s8 event, void *context);
static void Sim_Handler (u8 Event);
static void GPRS_Attach();
static s8 GprsHandler (u16 Event, u8 Cid);
static bool GprsCtrlHandler (adl_fcmEvent_e Event);
static bool GprsDataHandler( u16 DataLen, u8 *Data);
static bool CmdResponseHandler (adl_atResponse_t*paras);
static void TCP_Event_Handler (wip_event_t *event, void *ctx);
/*  Local functions        */
static void GPRS_Bearer_Handler (wip_bearer_t *br, s8 event, void *context)
    s8 Ret;
    switch(event)
        case WIP_BEV_CONN_FAILED:
        case WIP_BEV_IP_CONNECTED:
            adl_atSendResponse(ADL_AT_PORT_TYPE(ADL_PORT_UART1,ADL_AT_UNS), "\n IP Connected \n");
            TRACE((1,"GPRS-Bearer-Handler: %d", event));
            // TCP Client Socket create
            TcpSocket = wip_TCPClientCreate ("IPAdress",Port, TCP_Event_Handler,NULL);
                TRACE((1,"TcpSocket: %d", TcpSocket));
        case WIP_BEV_IP_DISCONNECTED:
        case WIP_BEV_STOPPED:
            adl_atSendResponse(ADL_AT_PORT_TYPE(ADL_PORT_UART1,ADL_AT_UNS), "\n IP Disconnected \n");
    switch (event->kind)
        case WIP_CEV_OPEN:
            adl_atSendResponse(ADL_AT_PORT_TYPE(ADL_PORT_UART1,ADL_AT_UNS), "\n Connection established successfully \n");
        break;
    TRACE ((1, "TCP-client Socket Event: %d", event->kind));
    s8 Ret;
    switch(Event)
        case ADL_SIM_EVENT_FULL_INIT:
            TRACE((1,"Sim full initialize"));
            adl_atSendResponse(ADL_AT_PORT_TYPE(ADL_PORT_UART1,ADL_AT_UNS), "\n Sim full initialized \n");
             //GPRS-Event Subscribe
            Ret = adl_gprsSubscribe (GprsHandler);
                TRACE((1, "GPRS-Event-Subscription Return: %d", Ret));
            //Attach to GPRS
            adl_atCmdCreate("AT+CGATT=1", ADL_AT_PORT_TYPE (ADL_PORT_UART1,FALSE),CmdResponseHandler,NULL);
        case ADL_SIM_EVENT_PIN_OK:
           TRACE ((1,"PIN ok"));
        break;
    TRACE((1,"Sim-Handler Event: %d", Event));
    return TRUE;
    s8 Ret;
    //GPRS Bearer
    //open Bearer
    Ret = wip_bearerOpen(&myBearer, "GPRS", GPRS_Bearer_Handler, NULL);
        TRACE((1, "Bearer Open Return: %d", Ret));
   //set GPRS Connection Parameters
            wip_bearerSetOpts (myBearer,
                                       WIP_BOPT_GPRS_APN, "APN",
                                       WIP_BOPT_LOGIN, "Username",
                                       WIP_BOPT_PASSWORD, "PW",
                                       WIP_BOPT_END);
    //Start
    Ret = wip_bearerStart (myBearer);
        TRACE((1, "Bearer Start Return: %d", Ret));
    s8 FcmGprs;
    s8 Ret;
    switch (Event)
        case ADL_GPRS_EVENT_ME_ATTACH:
            GPRS_Attach();
            adl_atSendResponse(ADL_AT_PORT_TYPE(ADL_PORT_UART1,ADL_AT_UNS), "\n GPRS Event Me Attach \n");
        break;
        case ADL_GPRS_EVENT_ACTIVATE_OK:
            Ret = adl_fcmSubscribe(ADL_PORT_GPRS_BASE, GprsCtrlHandler, GprsDataHandler);
                TRACE((1,"FCM-GPRS-Subscription: %d", Ret));
            adl_atSendResponse(ADL_AT_PORT_TYPE(ADL_PORT_UART1,ADL_AT_UNS), "\n GPRS Event Activate OK \n");
        break;
    TRACE (( 1, "GPRS-Event-Handler: %d", Event));
    switch (Event)
        case ADL_FCM_EVENT_FLOW_OPENNED:
            adl_atSendResponse(ADL_AT_PORT_TYPE(ADL_PORT_UART1,ADL_AT_UNS), "\n GPRS-Flow successfully opened \n");
            TRACE((1,"GPRS-Flow successfully opened"));
    TRACE((1, "FCM-GPRS-Flow-Control Event: %d", Event));
	return TRUE;
    adl_atSendResponse(ADL_AT_PORT_TYPE(ADL_PORT_UART1,ADL_AT_UNS), "\n GPRS-DataHandler executed \n");
    return TRUE;
/*  Function   : adl_main                                                  */
/*  Object     : Customer application initialisation                       */
/*  Variable Name     |IN |OUT|GLB|  Utilisation                           */
/*  InitType          |   |   |   |  Application start mode reason         */
    TRACE (( 1, "Embedded Application : Main" ));
    s32 SimSubs;
    SimSubs = adl_simSubscribe(Sim_Handler, "0000");
        TRACE((1, "Sim Subscription Return: %d", SimSubs));
    //TCP/IP Stack init
     s8 TCPIPRet;
     TCPIPRet = wip_netInit();
        TRACE((1, "wip_netInit: %d", TCPIPRet));
There is maybe something wrong in this code, or I use the function and Eventhandler in a wrong order or something else.
I’m very thankful for any help.
Thank you for spending time reading my post.
Kind regards
HW
