Fastrack Supreme LCP Termination Problem
Hello all,
I have dialup connection problem in Fastrack Supreme 20 modem. I could able to get dialup connection in wismoquick modem with the same options, Chat script and SIM card.
At this point I’am getting the problem
rcvd [LCP TermReq id=0x2]
LCP terminated by peer
Please see the below output of the chat script
ATQ0
ATV1&C1
ATE1
AT+CSQ
+CSQ: 27,0
AT&D2
AT+CMEE=1
AT+CGDCONT=1
AT+CGDCONT=1,“IP”,“airtelgprs.com”
AT+CGQREQ=1,0,0,0,0,0
AT+CGQMIN=1,0,0,0,0,0
ATD99**1#
CONNECT 115200
Serial connection established.
using channel 458
Using interface ppp0
Connect: ppp0 <–> /dev/ttyS1
sent [LCP ConfReq id=0x5 <asyncmap 0x0> <magic 0x8940732c> ]
rcvd [LCP ConfRej id=0x5 <magic 0x8940732c>]
sent [LCP ConfReq id=0x6 <asyncmap 0x0> ]
rcvd [LCP ConfAck id=0x6 <asyncmap 0x0> ]
rcvd [LCP ConfReq id=0x1 <mru 1500> <asyncmap 0x0> ]
sent [LCP ConfAck id=0x1 <mru 1500> <asyncmap 0x0> ]
sent [PAP AuthReq id=0x3 user=“9789981728” password=]
rcvd [PAP AuthAck id=0x3 “Welcome!”]
Remote message: Welcome!
PAP authentication succeeded
sent [IPCP ConfReq id=0x4 <addr 192.168.111.112>]
rcvd [IPCP ConfReq id=0x1 <addr 192.168.111.111>]
sent [IPCP ConfAck id=0x1 <addr 192.168.111.111>]
rcvd [IPCP ConfAck id=0x4 <addr 192.168.111.112>]
local IP address 192.168.111.112
remote IP address 192.168.111.111
Script /etc/ppp/ip-up started (pid 12216)
Script /etc/ppp/ip-up finished (pid 12216), status = 0x0
Connect time 0.0 minutes.
Sent 0 bytes, received 0 bytes.
Script /etc/ppp/ip-down started (pid 12225)
sent [LCP TermAck id=0x2]
Script /etc/ppp/ip-down finished (pid 12225), status = 0x0
Connection terminated.
Modem hangup
I made the DTR signal HIGH allways in Modem side externally as I dont have DTR output in my development board. Other than that I have TX,RX,CTS,RTS and Gnd signals flows from Board to Modem.
Any suggessions to solve this issue?
i have same problem :frowning:
how can i change default gateway [192.169.111.111]?
plz any 1 help us
I’m having the same problem with an FX100. Was there a solution?
Rowan
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: pppd options in effect:
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: debug debug debug#011#011# (from command line)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: nodetach#011#011# (from command line)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: holdoff 10#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: persist#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: logfd 2#011#011# (from command line)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: maxfail 0#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: dump#011#011# (from command line)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: noauth#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: user web#011#011# (from /etc/ppp/peers/voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: password ??????#011#011# (from /etc/ppp/peers/voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: /dev/ttyO4#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: 115200#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: lock#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: connect /usr/sbin/chat -v -t15 -f /etc/ppp/chatscripts/voda2.chat#011#011# (from /etc/ppp/peers/voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: modem#011#011# (from /etc/ppp/options)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: asyncmap 0#011#011# (from /etc/ppp/options)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: passive#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: lcp-echo-failure 4#011#011# (from /etc/ppp/options)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: lcp-echo-interval 30#011#011# (from /etc/ppp/options)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: hide-password#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: novj#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: noipdefault#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: defaultroute#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: usepeerdns#011#011# (from /etc/ppp/options-voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: noccp#011#011# (from /etc/ppp/peers/voda2)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: noipx#011#011# (from /etc/ppp/options)
Apr 11 12:37:42 meg78a504ff40ee pppd[6338]: pppd 2.4.5 started by ubuntu, uid 0
Apr 11 12:37:43 meg78a504ff40ee chat[6343]: abort on (BUSY)
Apr 11 12:37:43 meg78a504ff40ee chat[6343]: abort on (NO CARRIER)
Apr 11 12:37:43 meg78a504ff40ee chat[6343]: abort on (VOICE)
Apr 11 12:37:43 meg78a504ff40ee chat[6343]: abort on (NO DIALTONE)
Apr 11 12:37:43 meg78a504ff40ee chat[6343]: abort on (NO DIAL TONE)
Apr 11 12:37:43 meg78a504ff40ee chat[6343]: abort on (NO ANSWER)
Apr 11 12:37:43 meg78a504ff40ee chat[6343]: abort on (DELAYED)
Apr 11 12:37:43 meg78a504ff40ee chat[6343]: report (CONNECT)
Apr 11 12:37:43 meg78a504ff40ee chat[6343]: timeout set to 6 seconds
Apr 11 12:37:43 meg78a504ff40ee chat[6343]: send (ATQ0^M)
Apr 11 12:37:44 meg78a504ff40ee chat[6343]: expect (OKd)
Apr 11 12:37:44 meg78a504ff40ee chat[6343]: ATQ0^M^M
Apr 11 12:37:44 meg78a504ff40ee chat[6343]: OK^M
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: alarm
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: send (AT^M)
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: expect (OK)
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: AT^M^M
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: OK
Apr 11 12:37:50 meg78a504ff40ee chat[6343]:  -- got it
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: send (ATI^M)
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: ^M
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: ATI^M^M
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: Sierra Wireless^M
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: FX100 Product^M
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: send (ATZ^M)
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: ATZ^M^M
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: send (AT+CGDCONT=1,"IP","internet","0.0.0.0",0,0^M)
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: AT+CGDCONT=1,"IP","internet","0.0.0.0",0,0^M^M
Apr 11 12:37:50 meg78a504ff40ee chat[6343]: send (AT+CGQREQ=1,0,0,0,0,0^M)
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: expect (OK)
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: ^M
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: AT+CGQREQ=1,0,0,0,0,0^M^M
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: OK
Apr 11 12:37:51 meg78a504ff40ee chat[6343]:  -- got it
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: send (AT+CGQMIN=1,0,0,0,0,0^M)
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: AT+CGQMIN=1,0,0,0,0,0^M^M
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: send (ATDT*99***1#^M)
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: expect (CONNECT)
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: ATDT*99***1#^M^M
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: CONNECT
Apr 11 12:37:51 meg78a504ff40ee chat[6343]: send (\d)
Apr 11 12:37:52 meg78a504ff40ee pppd[6338]: Script /usr/sbin/chat -v -t15 -f /etc/ppp/chatscripts/voda2.chat finished (pid 6342), status = 0x0
Apr 11 12:37:52 meg78a504ff40ee pppd[6338]: Serial connection established.
Apr 11 12:37:52 meg78a504ff40ee pppd[6338]: using channel 6
Apr 11 12:37:52 meg78a504ff40ee pppd[6338]: Using interface ppp0
Apr 11 12:37:52 meg78a504ff40ee pppd[6338]: Connect: ppp0 <--> /dev/ttyO4
Apr 11 12:37:53 meg78a504ff40ee pppd[6338]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x6817ac3a> <pcomp> <accomp>]
Apr 11 12:37:53 meg78a504ff40ee pppd[6338]: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x6817ac3a> <pcomp> <accomp>]
Apr 11 12:37:54 meg78a504ff40ee pppd[6338]: rcvd [LCP ConfReq id=0x1 <mru 1500> <magic 0x3ab50c2a> <pcomp> <accomp> <auth pap>]
Apr 11 12:37:54 meg78a504ff40ee pppd[6338]: sent [LCP ConfAck id=0x1 <mru 1500> <magic 0x3ab50c2a> <pcomp> <accomp> <auth pap>]
Apr 11 12:37:54 meg78a504ff40ee pppd[6338]: sent [LCP EchoReq id=0x0 magic=0x6817ac3a]
Apr 11 12:37:54 meg78a504ff40ee pppd[6338]: sent [PAP AuthReq id=0x1 user="web" password=<hidden>]
Apr 11 12:37:57 meg78a504ff40ee pppd[6338]: sent [PAP AuthReq id=0x2 user="web" password=<hidden>]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: rcvd [PAP AuthAck id=0x2 "Welcome!"]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: Remote message: Welcome!
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: PAP authentication succeeded
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: rcvd [IPCP ConfReq id=0x1 <addr 192.168.111.111> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: sent [IPCP ConfRej id=0x1 <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: rcvd [IPCP ConfNak id=0x1 <addr 10.17.179.186> <ms-dns1 10.206.128.1> <ms-dns2 10.206.128.1>]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: sent [IPCP ConfReq id=0x2 <addr 10.17.179.186> <ms-dns1 10.206.128.1> <ms-dns2 10.206.128.1>]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: rcvd [IPCP ConfReq id=0x2 <addr 192.168.111.111>]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: sent [IPCP ConfAck id=0x2 <addr 192.168.111.111>]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: rcvd [IPCP ConfAck id=0x2 <addr 10.17.179.186> <ms-dns1 10.206.128.1> <ms-dns2 10.206.128.1>]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: not replacing existing default route via 192.168.1.254
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: local  IP address 10.17.179.186
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: remote IP address 192.168.111.111
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: primary   DNS address 10.206.128.1
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: secondary DNS address 10.206.128.1
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: Script /etc/ppp/ip-up started (pid 6374)
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: rcvd [LCP TermReq id=0x2]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: LCP terminated by peer
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: Connect time 0.0 minutes.
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: Sent 0 bytes, received 0 bytes.
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: sent [LCP TermAck id=0x2]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: rcvd [LCP TermAck id=0x2]
Apr 11 12:37:58 meg78a504ff40ee pppd[6338]: Connection terminated.
Hi…i am a new user here. In my case i just updated the libraries. I can try to resolve your problem if you can share some more information with me. Please share the details of the all components of your system. All the spe ifications of your hardware also.
