I recently bought the mangOH Red with WP7702 module. To use the extended AT commands, what is the OEM password that needs to be used with AT!ENTERCND command?
You can use At! entercnd=“A710”
Hi jyijyi - Thanks for your reply. I’d tried those command earlier but i’m getting an error.
At!entercnd=“A710”
ERROR
At!ENTERCND=“A710”
ERROR
This is strange, do you have one more module to test?
I don’t have any other module to test, just the one that came with the developer kit.
Other commands such as AT!MAPUART, AT!GETBAND, AT!GETRAT are returning valid results, so I don’t think there is any issue with the AT interface itself.
Problem is i don’t see error in this command.
I suspect this only happens one particular module.
