Errors in the RTE Library
Hi all,
it seems, there are some errors in the libraries which are linked to the debug version of the application.
For example: Converting the time to the timestamp using
adl_rtcConvertTime(&time, &timestamp, ADL_RTC_CONVERT_TO_TIMESTAMP)
shall give the time as unix time, which starts 1.1.1970 00:00. In the target version the function works right, but in the debug version the unix time will start at 1.1.1970 01:00. So the timestamp from 1.1.1970 01:00 on the target version is 3600 but in the debug version the timestamp is 0.
Is there a list available with errors in the rte libraries? I’m using OAT v3.10
Bye, Ralf
Hi Ralf,
It’s still the same in the OpenAT 4.20 in debug mode…
Best regards,
gdt
I’d like to bring this issue back to life. After 3 years of software evolution, things remain the same.
The following code …
adl_rtcConvertTime(&time1, &timestamp, ADL_RTC_CONVERT_TO_TIMESTAMP);
adl_rtcConvertTime(&time2, &timestamp, ADL_RTC_CONVERT_FROM_TIMESTAMP);
… will have this funny result: time2 will be 1 hour ahead of time1, in rte mode at least. (I’ll check in runtime when I find a spare moment).
I’m using OpenAT 4.21 with a Fastrack Supreme 10 6.63.
Not some effect of “daylight saving”, is it…?
Confirmed: once compiled and tested in the target device, the problem does not manifest.
So it is probably, as awneil suggested, a problem with the summer time configuration in the PC running the rte environment.
