Can you please share the rmnet drivers for em9293 module as i installed windows drivers and able to see modem port but rmnet drivers still not updated please advice and share drivers
What did you set for the following?
At!entercnd=“A710”
At!usbcomp?
It should be working fine for mbim interface
Output as below… i even updated qualcomm usb driver still rmnet does not work..
[12:23:20.691] Config Index: 1
[12:23:20.691] Config Type: 4 (MBIM V2)
[12:23:20.691] Interface bitmask: 00000109 (diag,modem,rmnet0)
[12:23:20.691]
[12:23:20.691] OK
I need to send ping from my device as rmnet does not come i cannot send it… if there way we install rmnet driver please share or if MBIM works fine can you please share the steps so that enbaled it on my system…thanks
How about setting at!usbcomp=1,4,1009 and reboot the module to enable mbim interface?
If i remember i did used this command at!usbcomp=1,41009 but did not work.. will try it on soon and will update in next couple of days.. this should enabled MBIM interface on windows system if this does not work any other way to work
not sure why other user can make it work with this MBIM interface, but you cannot
You need to debug your environment
I tried again it errors out can you please see the screen attached and let me if mbim is already configured if yes can you share the steps so that I see mbim works.
Also one query just want to understand if we buy the module does that it should not work right away either with rmnet and mbim once we plug in the device in windows pc and should be able to ping ?
sorry, it should be " at!usbcomp=1,4,1009" and then reboot the module.
Thanks for the correct command I can see the cellular connection but there is no internet connection any settings need to be done on cellular adaptor
What is the status of "at!gstatus? "
