EM9191 - USB interface information is unclear
The USB configuration of the modems is not understandable, i.e. the individual USB interface information is unclear. For this reason, it is currently not possible, for example, to create the AT interface (for AT commands) automatically. Can you tell us which USB interfaces there are and how they can be identified (bInterfaceClass, bInterfaceSubClass, bInterfaceProtocol).
Thanks in advance
In my testing in Ubuntu, it will create two ports:
/dev/ttyUSB0 and /dev/ttyUSB1
And /dev/ttyUSB0 is the AT command port.
Hmm… I’ll try to describe differently what we need: Is there any information about the USB configuration available (bInterfaceClass, bInterfaceSubClass, bInterfaceProtocol)? Most USB interfaces are not bound to a driver due unknown USB configuration. Could you please describe the exported USB interfaces? E.g. MBIM has bInterfaceClass 123, bInterfaceSubClass 321 …
can you find these information in windows device manager?
I can also show my test below (bus 03 port2)to see if you can find the information you want:
owner@ubuntu:~$ lsusb -t
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
    |__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/7p, 5000M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/7p, 12M
        |__ Port 1: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/7p, 480M
        |__ Port 1: Dev 5, If 0, Class=Communications, Driver=cdc_mbim, 480M
        |__ Port 1: Dev 5, If 1, Class=CDC Data, Driver=cdc_mbim, 480M
        |__ Port 1: Dev 5, If 3, Class=Vendor Specific Class, Driver=qcserial, 480M
        |__ Port 1: Dev 5, If 4, Class=Vendor Specific Class, Driver=qcserial, 480M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
    |__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/7p, 12M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
Bus 003 Device 005: ID 1199:90d3 Sierra Wireless, Inc.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x1199 Sierra Wireless, Inc.
  idProduct          0x90d3
  bcdDevice            0.06
  iManufacturer           1 Sierra Wireless, Incorporated
  iProduct                2 Sierra Wireless EM9191
  iSerial                 3 7821475120012345
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength          167
    bNumInterfaces          4
    bConfigurationValue     1
    iConfiguration          4 usb_mbim,serial,diag
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              500mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionClass          2 Communications
      bFunctionSubClass      14
      bFunctionProtocol       0
      iFunction               0
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         2 Communications
      bInterfaceSubClass     14
      bInterfaceProtocol      0
      iInterface              0
      CDC Header:
        bcdCDC               1.10
      CDC Union:
        bMasterInterface        0
        bSlaveInterface         1
      CDC MBIM:
        bcdMBIMVersion       1.00
        wMaxControlMessage   4096
        bNumberFilters       32
        bMaxFilterSize       128
        wMaxSegmentSize      2048
        bmNetworkCapabilities 0x20
          8-byte ntb input size
      UNRECOGNIZED CDC:  08 24 1c 00 01 40 dc 05
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass        10 CDC Data
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      2
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x8e  EP 14 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x0f  EP 15 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol     64
      iInterface              0
      ** UNRECOGNIZED:  05 24 00 10 01
      ** UNRECOGNIZED:  05 24 01 00 00
      ** UNRECOGNIZED:  04 24 02 02
      ** UNRECOGNIZED:  05 24 06 00 00
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x000a  1x 10 bytes
        bInterval               9
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceProtocol     48
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength           42
  bNumDeviceCaps          3
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000006
      Link Power Management (LPM) Supported
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x00
    wSpeedsSupported   0x000f
      Device can operate at Low Speed (1Mbps)
      Device can operate at Full Speed (12Mbps)
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   1
      Lowest fully-functional device speed is Full Speed (12Mbps)
    bU1DevExitLat           1 micro seconds
    bU2DevExitLat         500 micro seconds
  ** UNRECOGNIZED:  14 10 0a 00 01 00 00 00 00 11 00 00 30 40 0a 00 b0 40 0a 00
Device Status:     0x0000
  (Bus Powered)
Strange. Your decriptors are slightly different from the ones in
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/drivers/usb/serial/option.c?id=df3414b0a245f43476061fddd78cee7d6cff797f
You have this for intf #3 (AT port?):
i.e ff/ff/40 instead of the expected ff/00/00 according to the patch in mainline Linux.
The ff/ff/40 thing was someting we (or I at least) thought were related to SDX6x modems, like for example kernel/git/torvalds/linux.git - Linux kernel source tree
I guess we have to reconsider that assumption if what you show there is from a SDX55 modem. Did this change with some firmware revision, or has i always been like that under some condition? If so, what’s that condition?
I agree with @Sascha.Hoewisch that it would be nice to have some authoritative information on this… Been guessing the meaning of vendor specific descriptor layouts for more than 10 years now. Getting it more wrong than right. Some docs would be nice
I used mbpl usb driver instead of option.c
And i am testing with em9191
Is there documentation?
only see this document “Software_Integration_and_Development_Guide_for_Linux_USB_Platforms_R24.pdf” related to USB
https://source.sierrawireless.com/resources/airprime/software/mbpl/mbpl-software-latest/#sthash.E71FTiEO.dpbs
You might need to contact distributor to get other document.
