EM9191 - NMEA GPS Stream - Can not find the ttyUSB Interface
We use many generations of Sierra Wireless modems. Now with the new EM9191 generation we can no longer find GPS via ttyUSB. With the previous generations (e.g. EM7565, 7455) there was always a ttyUSB interface for the NMEA stream.
Why was this removed?
Can this interface be activated via AT?
Is there a firmware where this interface is available again?
Does this help?
Do not help.
It is QMI not a tty Interface.
Then I don’t see other method according to the response of AT!USBCOMP=?
BTW, is your product based on linux?
yes, we use linux.
our architecture use gpsd. that is the reason, why we need ttyUSB NMEA Stream.
can the gpsd get the NMEA data from QMI?
can you create a virtual port and forward those NMEA stream obtained by QMI to that port?
Sounds like a theoretical solution.
Do you have any experience or tools?
Why did Sierra Wireless decide to eliminate this interface? It could have remained adjustable via USBCOMP or via the interface bit mask.
Is it possible to offer the setting option again in the next firmware?
see if this helps to create virutal port:
maybe, I will check it. However, it sounds like a lot of work and testing to ensure that everything runs smoothly and reliably.
what about my other questions? Is it possible to unlock the NMEA stream again via the bitmask or has the NMEA -ttyUSB stream been completely removed from the firmware?
i don’t quite see there is such plan
That is very bad. Then we will probably have to rely on other modules in the future, although we were very satisfied with the performance and stability of the SW modems.
I have just tried the virtual port, it is working fine for my Ubuntu 18 to output NMEA frame in virtual port:
  1. sudo apt-get install libmbim-utils
  2. make sure MBIM port is enabled in AT!USBCOMP?
  3. connect antenna to AUX antenna port
  4. power on the EM9191 with FW SWIX55C_03.09.11.00
  5. Make sure GPSENABLE has been enabled in AT!CUSTOM?
  6. type AT!GPSAUTOSTART=1
  7. kernel log should show the following:
[  355.731518] usb 3-2.1: Product: Sierra Wireless EM9191
[  355.731519] usb 3-2.1: Manufacturer: Sierra Wireless, Incorporated
[  355.731520] usb 3-2.1: SerialNumber: 7821475120012345
[  355.842587] usbcore: registered new interface driver cdc_ncm
[  355.844384] usbcore: registered new interface driver cdc_wdm
[  355.975016] cdc_mbim 3-2.1:1.0: setting rx_max = 16384
[  356.012935] usbcore: registered new interface driver usbserial
[  356.013726] usbcore: registered new interface driver usbserial_generic
[  356.013811] usbserial: USB Serial support registered for generic
[  356.017132] usb_wwan: loading out-of-tree module taints kernel.
[  356.017170] usb_wwan: module verification failed: signature and/or required key missing - tainting kernel
[  356.020363] usbcore: registered new interface driver qcserial
[  356.021087] usbserial: USB Serial support registered for Qualcomm USB modem
[  356.021156] usbserial: USB Serial support registered for Qualcomm USB modem
[  356.023816] cdc_mbim 3-2.1:1.0: cdc-wdm0: USB WDM device
[  356.024230] cdc_mbim 3-2.1:1.0 wwan0: register 'cdc_mbim' at usb-0000:03:00.0-2.1, CDC MBIM, 5a:49:43:0c:a8:d1
[  356.025267] usbcore: registered new interface driver cdc_mbim
[  356.026301] qcserial 3-2.1:1.3: Qualcomm USB modem converter detected
[  356.026444] usb 3-2.1: Qualcomm USB modem converter now attached to ttyUSB0
[  356.030435] qcserial 3-2.1:1.4: Qualcomm USB modem converter detected
[  356.030631] usb 3-2.1: Qualcomm USB modem converter now attached to ttyUSB1
  1. Get the CID
owner@ubuntu:~/Downloads$  sudo qmicli -p --device=/dev/cdc-wdm0 --loc-start --client-no-release-cid --loc-session-id=53
[sudo] password for owner:
[/dev/cdc-wdm0] Successfully started location tracking (session id 53)
[/dev/cdc-wdm0] Client ID not released:
	Service: 'loc'
	    CID: '4'
  1. Put the CID in the following command and NMEA frame should be coming out.
owner@ubuntu:~/Downloads$ sudo qmicli -p --device=/dev/cdc-wdm0 --loc-follow-nmea --client-cid=4 --client-no-release-cid --loc-session-id=53
$GPGSV,1,1,03,30,26,203,13,07,10,178,,08,,,,1*63
$GQGSV,1,1,02,02,56,143,24,04,,,28,1*58
$GBGSV,2,1,08,01,47,122,,02,45,234,,03,63,188,,04,33,108,,1*72
$GBGSV,2,2,08,22,30,125,,24,44,286,,25,,,,26,50,209,,1*4C
$GAGSV,1,1,01,21,,,27,7*74
$GNDTM,P90,,,N,,W,,W84*4F
$GPGGA,034719.00,,,,,0,,,,,,,,*40
$GBGGA,034719.00,,,,,0,,,,,,,,*52
$GNGGA,034719.00,,,,,0,,,,,,,,*5E
$GNGNS,034719.00,,,,,NNN,,,,,,,V*41
$GBVTG,,T,,M,,N,,K,N*3E
$GNVTG,,T,,M,,N,,K,N*32
$GPRMC,,V,,,,,,,,,,N,V*29
$GBRMC,,V,,,,,,,,,,N,V*3B
$GNRMC,,V,,,,,,,,,,N*4D
$GBGSA,A,1,,,,,,,,,,,,,,,,*20
$GNGSA,A,1,,,,,,,,,,,,,,,,*2C
$GQGSV,1,1,02,02,56,143,23,04,,,30,1*56
$GPGGA,034720.00,,,,,0,,,,,,,,*4A
$GBGGA,034720.00,,,,,0,,,,,,,,*58
$GNGGA,034720.00,,,,,0,,,,,,,,*54
$GNGNS,034720.00,,,,,NNN,,,,,,,V*4B
^Ccancelling the operation...
	Service: 'loc'
	    CID: '4'
  1. install socat by “sudo apt-get install socat”
  2. sudo socat -d -d PTY,raw,echo=0,link=/dev/ttyVA00 PTY,raw,echo=0,link=/dev/ttyVB00
  3. now /dev/pts/1 and /dev/pts/2 should be generated
  4. sudo chmod 777 /dev/pts/1
  5. sudo chmod 777 /dev/pts/2
  6. to make sure these virtual ports work, you can use minicom to open these two ports and type some characters to verify
  7. use minicom to open /dev/pts/2
  8. sudo qmicli -p --device=/dev/cdc-wdm0 --loc-follow-nmea --client-cid=4 --client-no-release-cid --loc-session-id=53 > /dev/pts/1
  9. now the port /dev/pts/2 in minicom should output NMEA frame
