EM9191 and sysmoisim, IMSI changes after a few seconds
I can successfully provision a sysmocom Isim with a valid thirdparty eSim profile on an em9191. After enabling the the profile I can see in the radio trace the real IMSI of the sysmocom card. Even a network connection can be established. at+cimi reports the expected IMSI of the sim card. But after a few seconds, the IMSI changes to 15 times 9, the network connection breaks and every reattach is rejected. at+cimi reports this 15 times 9 too. Now I’m stuck, I have no idea what is happening or what I am missing. Anyone an idea or a hint?
TIA
andreas
The fw is the latest generic available:
Model: EM9191
Revision: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23
IMEI: 355890347224383
IMEI SV: 27
FSN: 783067204002B1
+GCAP: +CGSM,+DS,+ES
what is the return of the following?
ATi3
AT!impref?
at!uims?
AT+ccid
AT+CIMI
AT+CGDCONT?
AT!SELRAT?
AT!BAND?
AT!GSTATUS?
below the values you requested. I hope these give some insights. They are taken after the modem has switched the imsi (before it was 23210…)
andreas
ati3
Model: EM9191
IMEI SV: 27
FSN: 783067204002B1
+GCAP: +CGSM
at!impref?
!IMPREF:
 preferred fw version:    03.14.10.04
 preferred carrier name:  GENERIC
 preferred config name:   GENERIC_030.094_000
 preferred subpri index:  000
 current fw version:      03.14.10.04
 current carrier name:    GENERIC
 current config name:     GENERIC_030.094_000
 current subpri index:    000
at!uims?
!UIMS: 0
at+ccid
+CCID: 89852245280007924955,89044045116727494800000004481694
at+cimi
999999999999999
at+cgdcont?
+CGDCONT: 1,"IPV4V6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
at!selrat?
!SELRAT: Unknown RAT mode. Use AT!SELRAT to set band.
00001228
00000000
at!band?
Index, Name
00, All bands
at!gstatus?
!GSTATUS:
Current Time:  283		Temperature: 26
Thermal Mitigation Level: 0
Reset Counter: 1		Mode:        ONLINE
System mode:   WCDMA      	PS state:    Not attached
WCDMA band:    WCDMA 900
WCDMA channel: 2938
GMM (PS) state:DEREGISTERED   	LIMITED SERVICE
MM (CS) state: IDLE           	LIMITED SERVICE
WCDMA L1 state:L1M_PCH        	LAC:         1B68 (7016)
RRC state:   DISCONNECTED   	UTRAN Cell ID: C3FE2760 (10518885)
Rx0 RSSI C0:   -52		Rx1 RSSI C0:  ---
Rx0 RSSI C1:    --- 		Rx1 RSSI C1:  ---
AT!UIMS has been set to 0 which means physical sim slot, but not eSIM
Do you have an eSIM component connected to the physical SIM slot?
Yes, this sysmoisim is inserted in slot one.
then is that the physical sim card has problem?
how about setting AT!SELRAT=0?
What is the correct APN for this SIM?
Well, when I delete and re-provision the profile and insert the SIM into a Telit FN990 then I can establish a net connection. The IMSI stays as it should.
Regarding at!selrat=0, no change. And regarding the APN, I have to figure out.
For me it seems the modem ‘re-writes’ the IMSI and makes the SIM unusable.
then if you now put the workable SIM from FN990 to EM9191, can it establish data connection?
Yes, for a very short time it seems to work. Below a trace from our application to show the short time frame:
10.12.24 09:21:54 mbm3-2: Sierra Wireless EM9191@usb:3-2 appeared
10.12.24 09:22:00 mbm3-2: ICCID: 89852245280007924955
10.12.24 09:22:00 mbm3-2: IMSI: 232104070214249
10.12.24 09:22:00 mbm3-2: PIN ok
10.12.24 09:22:01 mbm3-2: Revision: SWIX55C_03.14.10.04 25b6d9 jenkins 2024/02/29 17:20:23
10.12.24 09:22:01 mbm3-2: IMEI: 355890347224383
10.12.24 09:22:01 mbm3-2: network connection on 22802 (RedteaGO) ready
10.12.24 09:22:01 mbm3-2: roaming from home 23210 to net 22802
10.12.24 09:22:01 mbm3-2: 60, 0f@LTE, RSSI:  -65dBm, RSRP:  -93dBm, RSRQ:  -11dB, SINR:    0dB
10.12.24 09:22:01 mbm3-2: Network time: 10.12.24 09:22:00
10.12.24 09:22:01 mbm3-2: PDP connection ready
10.12.24 09:22:01 mbm3-2: IP connection ready
10.12.24 09:22:02 mbm3-2: IP connection lost
10.12.24 09:22:02 mbm3-2: PDP connection lost
I even have a radio trace (QXDM enabled) where I see the the RRCConnectionSetupComplete (Attach Request) with the 23210 IMSI. 5 seconds later I see again an RRCConnectionSetupComplete with the magic 999 IMSI.
can you do a simple test by using manual registration (AT+COPS=1,2,xxx) to see whether it can register to network?
Unfortunately no success. At the time I type at+cops=1,2,“22802”, the IMSI has already changed.
Here a short correction, the sysmocom Product is here: sysmocom-euicc
If you type the command after imsi changed, can it register network?
at+cimi
999999999999999
at+cops?
+COPS: 1
at+cops=1,2,"22802",13
+CME ERROR: no network service
Is this sim card for multiple imsi configration?
Did you check if same apn is used in telit module?
I’m not aware of. I can not say yes or no.
Yes I did. The same apn is used in the telit module.
Maybe the network operator knows
Actually you need to contact distributor for qxdm log analysis
So, I verified the content of the primary eSIM profile before and after inserting it into the em9191.
The IMSI of the profile is 232104070214249 before inserting. After inserting and powering up the modem, the SIM changes to 999999999999999. So, the modem re-writes the IMSI on the profile. Due to whatever reasons.
I checked another eSIM profile regarding IMSI and here the IMSI stays the same. Seems that this is profile dependent. But I didn’t expect the modem to re-write the IMSI anyway.
Did you ever figure this out this IMSI rewriting? I had an almost identical scenario yesterday with a similar card as the sysmocom-euicc one, but with a different manufacturer / module:
Loaded the profile, inserted the card, had a register for a few moments, then it swapped to a denied registration, and then the IMSI was all 9s! Used yet a difference manufacturer / model, and everything worked fine … Back to the first device and it repeated itself, wiping out the IMSI – it drove me crazy for hours!
