We are replacing RC7620 with EM8695 for 5G Redcap.
We have a mode where the host buffers data into 6s or 30s chunks. It then uploads these periodically, i.e. every 6 or 30 seconds. Our previous 4G modem Sierra Wireless was RC7620. During the idle period between bursts, the modem goes into Sleep power state. We used the UART_DTR pin and removal of USB to enable this transition – this is to say, the host streams data via the UART port. The documentation says this sleep is higher/different to eDRX
Does the EM8695 support a similar behaviour? An obvious difference is the lack of UART on the EM8695. My reading of the product spec is power states are only Active, Off and disconnected. It mentions eDRX will be supported in a future release? Is the eDRX now supported in the latest firmware using CEDRXS? I see the power consumption in the datasheet is not provided for eDRX – presumably it will be lower than 2.56s DRX for 5G Redcap of 23mA typ and move towards 2.8mA low power mode – host suspended.
I would like to test it, but if not possible, estimating what it could be would be very helpful
Thank you
