EM7590 FW download failed - secret key is invalid, pls update the bootloader with se
Was trying to update the module FW. Linux OS. Using the fdtl tool. FW update failed. Error was secret key is invalid pls update the bootloader with se.
What does this mean? How to fix it?
Current FW is 01.01.07.00, trying to go to Verizon, 02.02.03.00. This is a new module direct from the Semtech factory.
are you using the latest version of fdtl?
https://source.sierrawireless.com/resources/airprime/software/fdtl-em7590/#sthash.hLsXqRz3.dpbs
I checked. I am not using the latest version. Ok we will update the version and retest.
We updated to the latest version, version 4.1.0. Test result - no good, same error.
See here,
Download failed – (remote: Secret key is invalid, please update the bootloader
how about upgrading in Windows?
Not possible. Module is inside a router. Looks like we have a module bug here. Can you check with R&D?
i don’t see problem to upgrade the FW of EM7595 in ubuntu 20 with this tool
What is the SKU of your module?
I will check and reply, thank you
We switched to using the MBPL fwdwl tool instead of the fdtl tool and that worked. The MBPL readme file explained how to use the MBPL fwdwl tool with the EM7590.
