jyijyi
April 3, 2024, 4:27pm
61
I don’t know why “no MBN adapter available” only happens to your EM7565 but not in your EM7455…
how about other older FW like SWI9X50C_01.08.04.00 or SWI9X50C_01.09.04.00 or SWI9X50C_01.07.02.00?
https://source.sierrawireless.com/resources/airprime/minicard/75xx/em_mc75xx-approved-fw-packages/#sthash.ZgFQbkts.4lDMNIPi.dpbs
Seems to be your module having problem
do you have another EM7565 to try?
HI @jyijyi ,
Unfortunately I don’t have other modem available. I will give it a try with the other images today (as I commented in my previous comment, these are carrier specific images, thought)
jyijyi:
SWI9X50C_01.08.04
I just tried with old Firmware as suggested, but I am getting the same error, so it seems not related to the image:
FDT version: 2.0.2012.0
Awaiting adapter ...
Firmware download failed.
Primary error code: 14 - No MBN adapter available.
Secondary error code: 0 - Not applicable.
Device error code: 0x0 - Unknown device error code.
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
Final images information:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Total time elapsed: 125 ms.
Images downloaded:
Press Enter to continue ...
Any other suggestion?
jyijyi
April 5, 2024, 1:01am
64
Probably you need to get another module to try
isn’t there any other way to trouble shoot it? any possibility to enable some logging trace to understand the cause of the failure? or to understand the error thrown in my attempts?
jyijyi
April 5, 2024, 2:30pm
66
Have you contacted distributor?
Have you tried to upgrade the firmware by AVMS?
That would be my next option (contacting the distributor)
in regards of AVMS, I am not familiar with it. Do you have any link or guidelines about how to do the upgrade?
jyijyi
April 5, 2024, 2:39pm
68
You can see here
https://doc.airvantage.net/fota/howto/gettingstarted/
Btw, can you download firmware after kickng module to boot mode by at!boothold ?
fdt2.exe -f SWI9X50C_01.14.22.00.cwe SWI9X50C_01.14.22.00_GENERIC_002.057_000.nvu
jyijyi:
at!boothold
I just contacted the distributor, let’s see if I get an appropriate answer that helps with this
jyijyi
April 6, 2024, 5:03am
70
actually I don’t know where you got this module.
It is very old one and the warranty had ended 4 years ago.
Anyway, you can try some older firmware according to this link:
I am stuck at Qdownloader here as well. If I understand correctly, I just need to try and update to an intermediate firmware build and then try the most recent build twice?
Also, where do I get a hold of an intermediate build?
Thank you for all your great posts folks.
