Hello everyone!
I’m having trouble with the serial device for my EM7455B. The device isn’t showing up.
~# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux 5.15.150 xhci-hcd xHCI Host Controller
Bus 001 Device 003: ID 413c:81b6 Sierra Wireless, Incorporated DW5811e Snapdragon™ X7 LTE
Bus 001 Device 002: ID 1a40:0101 USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux 5.15.150 xhci-hcd xHCI Host Controller
~# ls -alh /dev/tty*
crw-rw-rw- 1 root root 5, 0 Apr 3 16:23 /dev/tty
crw-rw---- 1 root dialout 4, 64 Jan 1 1970 /dev/ttyS0
crw-rw---- 1 root dialout 4, 65 Jan 1 1970 /dev/ttyS1
crw-rw---- 1 root dialout 4, 74 Jan 1 1970 /dev/ttyS10
crw-rw---- 1 root dialout 4, 75 Jan 1 1970 /dev/ttyS11
crw-rw---- 1 root dialout 4, 76 Jan 1 1970 /dev/ttyS12
crw-rw---- 1 root dialout 4, 77 Jan 1 1970 /dev/ttyS13
crw-rw---- 1 root dialout 4, 78 Jan 1 1970 /dev/ttyS14
crw-rw---- 1 root dialout 4, 79 Jan 1 1970 /dev/ttyS15
crw-rw---- 1 root dialout 4, 66 Jan 1 1970 /dev/ttyS2
crw-rw---- 1 root dialout 4, 67 Jan 1 1970 /dev/ttyS3
crw-rw---- 1 root dialout 4, 68 Jan 1 1970 /dev/ttyS4
crw-rw---- 1 root dialout 4, 69 Jan 1 1970 /dev/ttyS5
crw-rw---- 1 root dialout 4, 70 Jan 1 1970 /dev/ttyS6
crw-rw---- 1 root dialout 4, 71 Jan 1 1970 /dev/ttyS7
crw-rw---- 1 root dialout 4, 72 Jan 1 1970 /dev/ttyS8
crw-rw---- 1 root dialout 4, 73 Jan 1 1970 /dev/ttyS9
I’m running OpenWrt (23.05.3, r23809-234f1a2efa) on a Banana Pi BPI-R3.
I found in this forum these threads:
https://forum.sierrawireless.com/t/my-mc7710-cant-work-on-linux-after-plug-in-it-to-windows8/7986
https://forum.sierrawireless.com/t/em7455-error-with-usbcomp-over-cdc-wdm0/15571
Following the posts there I did send the posted hex commands to the modem. It seemed to work, or at least I did get the expected response from the modem, no error message. But still, after reboot, no serial device.
Unfortunately I can’t test the suggested perl script: https://www.thinkpenguin.com/files/em7455-modem-software/swi_setusbcomp.pl
OpenWrt does not contain the required perl packages.
I would be very thankful if someone could give me hint on how to enable the serial device for my modem.
