Hi Donald,
Thanks for your response.
We used a server called Netmotion MobileIQ to pull the information from mobile devices and display them in web portal. See the screenshot below.
You can see there is only cellular failure information for model FZ-55 (EM7511). We have another model laptop Panasonic CF-33 (EM7455B). However, no any cellular failure information FOR em7455b being published on that portal.
I checked with Netmotion services. After a couple of months investigation and tests, they told me there was no such information on the Cellular network interface (EM7455B) . So, I thought this model might not enable logging for that failure event by default. Or it did generate the log, but Netmotion didn’t figure how to retrieve it. I don’t what command they used to retrieve the information. I have asked them, but haven’t gotten response yet.
Do you know if any command can read the cellular failure information from the module?
I attached the result of AT commands below.
ATI9
Model: EM7455B
Revision: SWI9X30C_02.32.11.00 r8042 CARMD-EV-FRMWR2 2019/05/15 21:52:20
MEID: 99000824227613
IMEI: 990008242276132
IMEI SV: 19
FSN: LF008142740210
+GCAP: +CGSM,+DS,+ES
AT!ENTERCND=“a710”
ERROR
AT!IMPREF?
!IMPREF:
preferred fw version: 02.32.11.00
preferred carrier name: ROGERS
preferred config name: ROGERS_001.040_001
preferred subpri index: 000
current fw version: 02.32.11.00
current carrier name: ROGERS
current config name: ROGERS_001.040_001
current subpri index: 000
AT+CPIN?
+CPIN: READY
AT+CIMI
302720591080405
AT+CCID
+CCID: 89302720395911304829
AT+COPS?
+COPS: 0,0,“ROGERS”,2
AT!GSTATUS?
!GSTATUS:
Current Time: 1172909 Temperature: 27
Reset Counter: 1 Mode: ONLINE
System mode: WCDMA PS state: Attached
WCDMA band: WCDMA 850
WCDMA channel: 1037
GMM (PS) state:REGISTERED NORMAL SERVICE
MM (CS) state: IDLE NORMAL SERVICE
WCDMA L1 state:L1M_PCH_SLEEP LAC: E86C (59500)
RRC state: DISCONNECTED UTRAN Cell ID: 003B5998 (3889560)
RxM RSSI C0: -87 RxD RSSI C0: —
RxM RSSI C1: — RxD RSSI C1: —
AT!USBCOMP?
ERROR
AT!UIMS?
!UIMS: 0
AT+CGDCONT?
+CGDCONT: 1,“IPV4V6”,“ROGERS.APN”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
Thank you!
